PC Low System Battery Warning
Posted 11/12/2011 - 10:44
If you are referring to a desktop, then it sounds like it's the CMOS battery that needs replaced. If you take the side off the casing to expose the MoBo (motherboard) - remember to power down AND unplug it first - somewhere on the mobo you should see a little button battery (about the size of a 1p coin). Remove this battery, and go buy a replacement. Boots, Superdrug, etc might have them in stock - there should be no need to visit a specialist computer shop.
Before removing this battery, touch the metal frame of the casing with both hands to discharge any static electricity your body has produced - likewise when you replace the battery too!
Good luck!!
Good luck!!
Posted 11/12/2011 - 10:51
Thanks for the quick response Steve, it is a desktop, are there no settings checking / making etc after replacing ?
If not thats great
If not thats great
Chris
Posted 11/12/2011 - 10:58
As far as I can recall, everything should be pretty much as normal. You might need to boot into the BIOS though, to reset the time and date. If that's the case, once you have changed the CMOS settings from the BIOS, save and exit (usually the F10 key), then reboot your machine.
When your machine powers up, it should tell you which key to press to enter the BOOT MENU.
No settings to save..Just swap the battery. Bob's your auntie..
Stuart..
Stuart..
Posted 11/12/2011 - 12:06
Excellent, Thank you Stuart / Steven for the replies.
Chris
Posted 11/12/2011 - 13:48
You shouldn't remove the battery
It's still holding your cmos/bios settings.... if you remove
it all will be lost and you will need the motherboard manual
to reset some of them such as CPU speed.
Try to read it in the machine with a magnifying glass
if need be. It might be in the manual.
It's probably a CR2032 or Cr2025 .... 20 is the diam.
32 is the thickness = 3.2mm etc. Readily available even
in some supermarkets.
Quickly swap the new battery over.
Posted 11/12/2011 - 14:00
Thanks Algi, it is a CR2032, will get one tomorrow and swap over.
Chris
Posted 13/12/2011 - 14:57
If you're not in a hurry, I had to get some cr2032 for my father's Dell PC. 7dayshop were extremely cheap for them, £2.99 for 12 panasonic cr2032 batteries with free postage.
Absinthe makes the heart grow fonder.
Pentax k100d, kit lens & Tamron 70-300
Posted 13/12/2011 - 17:02
I'm assuming all's well now, Chris??
Posted 13/12/2011 - 19:16
Hmmmm.... not yet, been to busy work wise and been away from home, to get a battery, written a note as a reminder for tomorrow, thanks for the prompt
Chris
Chris
Chris
Posted 13/12/2011 - 19:28
Just to add, avoid touching the battery with your hand. Try using a tissue. It just stops grease getting on and causing a short circuit.
Posted 14/12/2011 - 16:58
Job Done, Thank you for all your input & instruction, really appreciated
Chris
Posted 14/12/2011 - 18:12
No probs, buddy!!
St Austell,
Cornwall
I'm ok with delving into the casing, but is this a DIY job and whats involved please, do I need to make a note of settings and where from ?
The systems a 7-10 year old Dell
Many Thanks in advance
