P30 advance lever screws
Sagaqualified
Posted 28/06/2011 - 14:07 Link
After half a film shooting, my recently obtained P30's advance lever went floppy, then parted company from the assembly. The retaining screw has worked loose but looks ok. However I can't fix the xxxxing thing as the 2 tiny screws that hold the metal backplate to the plastic lever arm won't budge under normal pressure from an instrument screwdriver. Has anyone had this problem and more importantly is there a simple solution?
Outside of a dog, a book is man's best friend. Inside of a dog, it's too dark to read.
Dangermouse
Posted 28/06/2011 - 14:11 Link
I'd guess that these were done up by the Asahi works sumo team (I keep finding parts on cameras which appear to have been tightened with a torque wrench). Try a tiny drop of lighter fuel on them as this can sometimes break the friction and enable you to turn them.
I've also had success with an instrument screwdriver and a pair of small pliers. Grip the screwdriver with the pliers, then while jamming it hard into the screw head use your free hand to attempt to turn it. The extra leverage may help (or may equally shear the screw off, so be careful!)
JohnX
Posted 28/06/2011 - 14:49 Link
Just in case you need it, service manual here;
http://pentax-manuals.com/manuals/service/p30_service.pdf
Password is 'Pentax' - note high case 'P'.
JohnX
Posted 28/06/2011 - 14:54 Link
Also, here's someone who had a similar problem;
http://forum.mflenses.com/pentax-p30t-broken-advance-lever-t29255.html
Edited by JohnX: 28/06/2011 - 14:54
Sagaqualified
Posted 20/07/2011 - 09:10 Link
Well, got it done at the weekend!! This is how:
Take a micropoint soldering iron (free of solder) and place it on the head of each of the 2 screws that hold the metal plate to the plastic cover for about a minute. Take care not to slip and damage the plastic.
Then place the assembly in a freezer for 10 minutes.
Try the screw with a precision screwdriver if still tight repeat process until successful. One screw came off first time the second needed another cycle.
Whole assembly now refitted to the P30
