over exposure using fill in flash
Posted 27/08/2013 - 08:35 Link
can we see some pics please
the comments make sense and I can see how this might be about the camera running out of adjustment options, but we don't really have enough information to be more definitive
Trubshore
Posted 27/08/2013 - 08:52 Link
Trubshore
Posted 27/08/2013 - 09:03 Link
[Many thanks for all your troubles and replies.
I am using centre weighted metering.
the flash is conected to the camera using a Nissin universal shoe cord SC-01.
The two images are straight from the camera
dpm
Posted 27/08/2013 - 09:26 Link
the dark areas are exposed perfectly no?
Try spot metering.
Posted 27/08/2013 - 09:32 Link
highlights look blown to me
be good to know the Aperture, Shutter, ISO but I think the camera is running out of adjustments
JohnX
Posted 27/08/2013 - 09:39 Link
Trubshore wrote:
.. and AF-360 FGZ flash on a offset bracket
So presumably manual settings on the flash or do you have a off-camera cable controlling/firing it?
Edited by JohnX: 27/08/2013 - 09:40
sterretje
Posted 27/08/2013 - 09:47 Link
From the first image, it's clear that the background is (also) overexposed. This is not a result of the flash overexposing but the conditions are just too bright for the given shutter speed / aperture / ISO. I think that the same applies to the second one, but I find that a bit more difficult to judge.
Lower your ISO to 100 (1 stop less overexposure), close the aperture so you have correct exposure (check in the viewfinder !!). You will have (a lot) more DOF which might not be what you want; in which case HSS is the way to go.
JAK
Posted 27/08/2013 - 10:42 Link
The exif data on these images is intact. Install fxif or similar which gives you:
Camera Maker: PENTAX
Camera Model: PENTAX K-5
Lens: smc PENTAX-DA* 50-135mm F2.8 ED [IF] SDM
Image Date: 2013-08-25 13:19:32 +0100
Focal Length: 80.0mm (35mm equivalent: 120mm)
Aperture: f/6.3
Exposure Time: 0.0056 s (1/180)
ISO equiv: 200
Exposure Bias: none
Metering Mode: Center Weight
Exposure: aperture priority (semi-auto)
White Balance: Auto
Flash Fired: Yes (enforced)
Orientation: Normal
Color Space: sRGB
GPS Coordinate: undefined, undefined
Creator: PETER ELTON
Copyright: PETER ELTON
Software: Adobe Photoshop CS4 Windows
JohnK
Mongoose
Posted 27/08/2013 - 12:21 Link
don't forget that as soon as the flash is kicked in, your top shutter speed is reduced to 1/180th (unless you have a HSS capable flash, but then you lose flash output)
This makes it quite likely that you'll blow out the background in sunlight, just because the camera has nowhere to go with the exposure.
I'm no expert on flash because I rarely carry mine around with me, but on the rare occasions I do use it for fill in I tend to start off in Tv mode on 1/180th, set up the exposure for the rest of the frame and THEN activate the flash.
but it does help
Posted 27/08/2013 - 13:08 Link
ok, taking a simplistic "sunny 16" view of exposure f6.3 is too wide
I tend to agree with mongoose, if you want to stick to the camera doing the work the Tv and 1/180 is a good place to start. ISO 100 in bright sun might help
Edited by LittleSkink: 27/08/2013 - 13:09
McGregNi
Posted 27/08/2013 - 16:02 Link
sterrejte was right earlier - I missed that fact that in Av mode in this scenario, the camera's exposure is effectively locked at way too bright!
Av holds the aperture, shutter speed is 180th max, and ISO is also fixed. The camera cannot 'do it' with these settings.
That doesn't explain why P mode didn't work though - with this setting then the aperture would be free to stop down. The shots are what, 2 to 3 stops overexposed? So f11 or f16 should be getting closer?
Not great apertures for these portraits though. But the next thing for the OP to test is that these ambient exposure settings actually work. I would suggest as an experiment trying a similar scene, set in Tv mode 180th sec, record the aperture the camera gives you, then manually set this (with any minor adjustment if you want it a bit darker or brighter).
I'm assuming the settings will be something like 180th sec & f16. I'd agree with sterrejte also on using ISO 100. These will now all be fixed, and the ambient exposure should be OK.
It gets more fun now - how the flash power is controlled depends on the unit and its connections. But I still think the simplest way is basic aperture and / or distance. As Gartmore said earlier, you want about '1 stop' less than 'normal' flash for this fill-in type. So f16 might be about right! Try it, and if the face is still too bright then move the flash further away and try again.
Posted 27/08/2013 - 16:08 Link
one thing I do in bright situations like these is use a polariser if I want shallow d-o-f
thanks for all the comments folks - learnt a bit about outdoor flash from here
Trubshore
Posted 27/08/2013 - 18:26 Link
Many thanks for all your comments.
I know know a lot more about flash photography than I did before and hope that on my next outing I will be able to put it to good use.
Once again many thanks.Peter
Horst
Posted 28/08/2013 - 14:52 Link
Try using a ND Filter of 2 -3. Then you can keep the small dof. and use the AV setting.
Regards, Horst
