Optio S50
Anonymous
Posted 04/01/2006 - 18:20 Link
When connecting my Optio S50 to the computer I get the message "A USB device has malfunctioned and exceded the limits of its hub port. You should disconnect the device" Can this apparent camera fault be fixed?
George Lazarette
Posted 04/01/2006 - 20:04 Link
The solution is to use a card reader.
Posted 04/01/2006 - 22:16 Link
Have you connected the camera into a hub? If so, it sounds like you've overloaded the power requirements. (Each USB device can specify how much current it will take to the host computer. A hub can only dish out so much power, and as far as I remember, you get that message when it's max'd out!)
You could try connecting directly into the computer, or better still (as George so tersely put it) get a card reader which often saves a lot of hassle (and if you have USB2 and get a USB2 reader, will work a lot faster than the camera too!)
George Lazarette
Posted 05/01/2006 - 00:01 Link
Terse? I prefer succinct.
Anonymous
Posted 05/01/2006 - 21:23 Link
I have an optio s5z. As soon as the usb cable is connected to an xp pc it states that there has been a power surge and freezes the pc (the laptop just shuts down. (have 2 pcs & a laptop & all get the same result). If I plug it into an ancient p3 windows 98 pc it works fine!
any ideas? apart from getting a card reader.
Surely this should not be happening
George Lazarette
Posted 05/01/2006 - 22:01 Link
No ideas (apart from getting a card reader)!
But you could try writing to:
William Gates, Jnr.,
Microsoft Corporation
One Microsoft Way
Redmond, WA 98052-6399
USA
Kim C
Posted 06/01/2006 - 08:46 Link
One answer might be to use a powered hub so that the supply is coming from the hub rather than the PC. However, a card reader is much more convenient.
Kim
Posted 06/01/2006 - 09:25 Link
Get a card reader.
(How's about that for terse, George )
I've seen them for as little as £1.99 (try www.7dayshop.com if you're in the UK - £7 for a reads-all-reader and £4.50 for SD-only)
George Lazarette
Posted 07/01/2006 - 21:00 Link
Get a card reader.
Tres succinct.
