Optio 750Z
Posted 30/09/2006 - 10:43
You could double-check that the battery contacts are clean and making proper contact. Is the charger lighting up properly when charging?
Otherwise, it's back for a repair, and seeing it's so close to the warranty period i would be inclined to see if Pentax would stretch a point for you and do a warranty repair. After all, there's nothing to lose by asking.
Posted 30/09/2006 - 11:15
Thanks once more for your help. John. The charger is charging properly and I have looked at the battery contacts. I will try to appeal to pentax uk's better nature on Monday morning then.
Posted 30/09/2006 - 12:19
If you are within range of Slough, I would advise you to go in and see them. They're quite friendly, and may stretch a point if they see you in person.
21 years
