Optical trigger !?
Posted 19/11/2009 - 14:56
I would think so
Posted 19/11/2009 - 16:08
gartmore wrote:
I would think so
u don't sound too sure !? I would think so
Maybe I'll wait for the next comment
Posted 19/11/2009 - 16:39
I am sure! People have used them for decades before low trigger voltages were ever heard of. Honest!
Posted 19/11/2009 - 16:42
Most optical triggers use an SCR device, as far as I know.
There's always the possibility that it could fry the optical slave - but that's much, much cheaper than frying a body
There is also the Wein Safe Syncs that allow coupling for very high trigger voltages... but that'll probably be more than you want to pay.
http://www.weinproducts.com/safesyncs.htm
Personally, I'd try the optical one and risk frying it (though I'd say 75% chance it'll work fine).
Sorry can't help much more!
Posted 19/11/2009 - 17:34
I have been using a pair of Seagull SYK3 triggers for 3 years now with my old Vivitar 283 flashguns, trigger voltage measured at 270 volts, with no problem. In fact I have just increased my collection of this combination by 2 more sets to use as inexpensive studio strobes.
John
Posted 19/11/2009 - 17:37
K10D wrote:
I built something similar to this for an old Elinchrome.
The TIC106D is the standard choice and readily available.
Another more flexible circuit
The Opto isolator is 100% safe.
Thanks for that, I like the sound activated one, might build that !?I built something similar to this for an old Elinchrome.
Being an electronics engineer, I know what's inside them but as they're sealed I can't see which output device they use, so have no idea of the max operating voltage. Guess I'll just have to try it and see
Posted 19/11/2009 - 17:41
Just don't forget and pop it on your camera one day I have been using a pair of Seagull SYK3 triggers for 3 years now with my old Vivitar 283 flashguns, trigger voltage measured at 270 volts, with no problem. In fact I have just increased my collection of this combination by 2 more sets to use as inexpensive studio strobes.
Having said that our cameras use a similar (if not identical) circuit to these Opto switches, so should survive I'm not trying it out on mine though
Posted 19/11/2009 - 17:44
As u say Matt ; safer than frying my K10 just wondered if anyone knew the rated voltage
Posted 19/11/2009 - 17:49
I have labelled all my old flashguns with the measured trigger voltage so that hopefully (senior moments permitting) this does not happen!
John
Posted 19/11/2009 - 17:59
digikid-tv wrote:
I have labelled all my old flashguns with the measured trigger voltage so that hopefully (senior moments permitting) this does not happen!digikid-tv wrote:
I know the 283/285 have manual settings, but what else is out there with at least 1/16. 1/4 and full options. Finding it difficult to find any manual flashes (CHEAP and probably old, of course). Don't need the fancy stuff (TTL, P-TTL, Auto, etc.), but so many on ebay don't give a reasonable description of what they can do, so I need to know the model numbers ! Hope u can help
Posted 19/11/2009 - 18:15
I setled on the Vivitar 283 as they are very cheap, plentiful and powerful.
They need the VP1 varipower module to operate in a fully variable mode, this plugs in in front of the flash in place of the sensor. The range available is from full power down to about -5.5 stops.
Unfortunately this module is rare and thus relatively expensive to buy nowadays. However it only contains a 100k ohm potentiometer, a series resistor of 3.9k ohms and a 200 picofarad capacitor and I have successfully modified two of my units by mounting these parts in a small plastic box mounted in place of the sensor.
I am abroad at the moment but could send more details when I get home next week.
John
Posted 19/11/2009 - 19:01
Thanks for that, more details would be good
UK
Just bought a Hanimex TZ*2 and it outputs ~230 volts !! Wow !!
