Opinions on two lenses
Darkman
Posted 22/06/2010 - 19:41 Link
hi there l am looking for opinions on the following lenses.
Smc da 50-200 f4-5.6
Smc fa 28-200 f3.8-5.6
Are there any issues i should look for or beware of?
Is there any reason to discount either of them?
JonSchick
Posted 22/06/2010 - 20:01 - Helpful Comment Link
The main reason for you to discount the 50-200 is that you already have the Tamron 70-300 - which is a pretty decent sharp lens that will outperform the 50-200 probably from around 150mm onwards and also gives you a reasonable macro capability.
The reason to make the change to the 50-200 would be if you (a) want a much more compact lens or (b) want one that has less purple fringing. Some people don't love the colours that come out of the Tamron either - a little cool compared to the Pentax.
I have no experience of the other lens so others will need to advise. I suspect, though, that it is unlikely to perform better than your kit lens and Tamron combination.
Jon
Some occasional random stuff at The Photographers Block: link
Darkman
Posted 22/06/2010 - 20:30 Link
am going to be getting a k10d before the weekend so the lens is so my son can use the k100d which was why i was looking at the 28-200 but was looking for other options.
50-200 ED WR
50-200 DAL ED
Would either of these be a good budget buy?
JonSchick
Posted 22/06/2010 - 21:10 Link
Ah! - my son (age 12) has also inherited my K100D, which he mostly uses with the kit lens. I find that he often wants to take photographs of things (mostly our pets) indoors in the worst possible lighting conditions, which makes providing him with cheap low light lens options is a struggle!
I have the 50-200 ED WR lens - despite all that I wrote above(!) - and am very happy with it. If you can find one at a decent price, I think it performs more than adequately, is nicely put together and has the advantage of being very compact.
The advantages over the DAL lens, which I think is optically identical, will be that it comes with a lens hood (keeps your son's fingers from smearing all over the lens!), has quick shift focus, which means you can make manual adjustments to the focus even when the lens is in autofocus mode (very helpful) and has a metal mount. Oh - and the WR lens looks nicer too!
Jon
JonSchick
Posted 22/06/2010 - 21:11 Link
PS - the WR is weather resistant which is not an issue with the K100D, but useful if you borrow it for the K10D!
Jon
Anvh
Posted 22/06/2010 - 21:25 Link
Darkman wrote:
50-200 ED WR
50-200 DAL ED
Optical they are the same but the WR has newer coating and is weather resistance, so with the WR lens and the K10D combined you can walk in the rain without worries.
oops you named the DAL version.
That one is the light weight version and doesn't have a hood and quick-shift. It also has a plastic lens mount rather than a metal one.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 22/06/2010 - 21:27
GlynM
Posted 22/06/2010 - 22:03 Link
I thought that as no one else has come forward I should write something about FA28-200. For some reason, and I can't imagine why, I seem to own two of these and I can't remember the last time I actually used either.
It is a big heavy lens. It has 72mm threads on the front. Closed up its not dissimilar in size to a DA*16-50 and I've always felt that was a bit of a monster.
Its a fairly old design lens and rumour has that it is Pentax re-badge and SMC coated, version of a Tamron or Tonkia lens. It is a full field lens so I guess it should in theory have a sweet spot when used on an APSC DSLR. However my feeling is, though, that its performance is mediocre compared with a modern DSLR lens. It does allow manual adjustment of the aperture which you don't get on DA lenses.
It has a two trombone zoom mechanism, well used ones can suffer from zoom creep and the zoom mechanism is a bit stiff on mine. It does have internal focusing so the front does not rotate with focus movement (which is the thing I hate about the Tamron 70-300 where trying to fit the hood can force the focus drive train :evil. It is from an era before quick-shift focus and the focus movement is only around 20-30 degrees so manual focusing is a bit of a pain.
I think the biggest issue though is is its zoom range. 28mm on a FF camera is about the same as an 18mm on an APSC but 28mm on a APSC is like 42mm. I just don't think its wide enough to make a useful range on on an APSC DSLR.
If you can get a good one (no creeping) cheap though it might be worth having but I think in your place I would be going for a DA 55-300 (much better, I think, than the 50-200) and dumping the 70-300.
Glyn
Edited by GlynM: 22/06/2010 - 22:06
Anvh
Posted 23/06/2010 - 11:24 Link
Yeah get yourself a DA55-300 and give your son the Tamron
Stefan
K10D, K5
AF-540FGZ
Darkman
Posted 24/06/2010 - 10:44 Link
cheers- help much appreciated
sam-joseph
Posted 24/06/2010 - 12:31 Link
Get your son a smc Pentax-a 50mm f1.7 and teach him how to manual focus. The results will be worth it.
Sam-Joseph
Pentax K7, Sigma 17-70 f2.8-4.5, Sigma 70-200 f2.8 APO EX, Sigma 70-300 APO, Sigma 1.4x TC, Vivitar 2x TC. Takumar 135mm f2.5, SMC Pentax A 50mm 1:1.7, SMC Pentax -M 1:4 200mm, Pentax X70
