Oooops, there goes my camera.
Posted 29/03/2019 - 18:29
I hope you can fix it, and nothing else is damaged!
Posted 29/03/2019 - 18:32
Scary, let us know how you get on.
Just make sure you never drop it with a flash attached - it'll snap the hotshoe right off!
All the gear with no idea
Posted 29/03/2019 - 20:28
Good luck with it...
Stuart..
Stuart..
Posted 29/03/2019 - 21:36
Similar happened to me in a hide with a K50 + Sigma 150-500, resting on the shelf when some prat lifted the flap and knocked them to the floor! Not a mark luckily, just shows how robust they are. Good luck with fixing the strut.
Posted 29/03/2019 - 22:12
Ooooh dear that's most vexing but testament nevertheless to the robustness of the Pentax K1.
I feel sure though that it will be a relatively easy fix.
Fingers crossed and good luck.
C.O.L.B.A.S victim
Posted 30/03/2019 - 03:47
Ouch, that hurts!
Hope you manage to fix it!
Posted 07/04/2019 - 22:20
Well it turned out to be a fairly easy fix, pull the rubber away, remove 4 small screws (as usual I managed to lose one but found it wedged in between the rubber) and then remove the rail. place the leg back in and then screw it all back.
Works fine now ... had that been my D500 I think it would have been a totally different story.
Posted 07/04/2019 - 23:23
Cool story, sad but has a happy ending.
Posted 08/04/2019 - 08:19
Phew, glad you had a happy ending!
Internet is grand sometimes isn't it?
Posted 08/04/2019 - 08:57
It could have been a lot worse....
Hythe,
Hampshire UK
Camera is actually unmarked and so is the lens and everything seems to work just fine but I have popped a strut on the rear screen. Looks like there is a fix on Pentaxforums, just building up the courage.
