Only a slight concern
Zach Abubeker
Posted 15/08/2007 - 03:15 Link
So the other day i was cleaning some debris from my k10 and noticed the rubber grip near the SD compartment was a bit loose. It sort of peeled up a bit not disastrously but with time it will definetly nullify the 'weather sealed' feature, maybe it truely isnt now. anyone have any suggestions? Call Pentax im assuming?
Posted 15/08/2007 - 07:48 Link
Get it fixed whilst still under warranty would be my choice.
Don
Posted 15/08/2007 - 14:58 Link
the rubber padding on the outside should not have anythibg to do with the weather seals. proper weather sealing comes from A)having as few holes as possible in the outer plastic body. and B)putting rubber gaskets in to seal those openings.
a rubber pad, used on the part where you grip it, is cosmetic, not part of any seal...at least thats the way it should be done.
a little corner on my mz5 grip lifted a bit, and stayed that way for years without actually comming right off.
Zach Abubeker
Posted 15/08/2007 - 15:43 Link
Thanks much.
