Old k lenses
python118
Posted 26/05/2016 - 13:47 Link
Hi, does any one know how to enable the use of k lenses with the k3
Thank you
Dave
JAK
Posted 26/05/2016 - 14:01 Link
Select [Enable] in [27. Using Aperture Ring] of the C4 menu.
Use exposure Mode M
Press the green button to take a meter reading.
There is further info on this on page 84 of the K3 manual.
Edited by JAK: 26/05/2016 - 14:02
bforbes
It's in The "C" menus. You have to allow "Using Aperture Ring".
Quick typing there John
Edited by bforbes: 26/05/2016 - 14:03
python118
Posted 26/05/2016 - 20:26 Link
Thank you
Regards Dave
geordie01
Posted 27/05/2016 - 10:34 Link
If you demount the lens and turn it about 10 degrees you can use the lens in AV mode and it will meter without the green button
doingthebobs
Posted 27/05/2016 - 22:02 Link
Also gives 'depth is field preview' as it stops the lens down!
Bob
Posted 28/05/2016 - 00:54 Link
You mean, insert lens into the mount in the usual way but only turn it 10 degrees? This is a new trick for me.
10minutes later ........
Good Heavens. It works with a K5 and a Chinon 50mm f1.7 - bit risky with the loose lens though. The info says it used f1.7 nevertheless -- it didn't -- it stopped it down to f8 so, although it works it doesn't report truthfully
My page on Photocrowd
Edited by davidwozhere: 28/05/2016 - 01:03
geordie01
Posted 28/05/2016 - 08:22 Link
It will not report aperture as there are no contacts but if you want a secure lens you can ddrill a 3mm hole in the lens mount about 10degrees form the lens lock on the mount and it will fit on the camera securely
