off camera flash system
Posted 07/01/2011 - 11:28
Hi James - long time no see
In my version of the manual for the Pentax AF540FGZ flash, at page 19 it states,
"When using multiple flash units set to P-TTL or TTL Auto and adjusting the amount of light at the same time, use the camera's exposure compensation".
Assuming I am interpreting this correctly, that tells me you can set the output for these flashes while off-camera, using the Ev control on the camera itself.
Hope that helps...
Edit - if by trigger however you're referring to a flash mounted on the camera, what I've outlined here is not what you want at all!
Hope that helps...
Posted 07/01/2011 - 11:33
thank you I-berg
It's the Quantum Qflash TRIO that I've seen but sadly it's not produced for the pentax
shown here
James
shown here
James
My Fluidr
Posted 07/01/2011 - 11:55
That's flash looking gear (if you'll pardon the pun!)
Posted 07/01/2011 - 13:33
Quantum kit is just about the best there is, I use the batteries on my Pentax hammerhead flashes, pricey though at £300 per battery but you get mains power performance and 1000 flashes per charge.
Sadly Quantum haven't supported Pentax for around 20 years.
Warwickshire
can anyone point me in the right direction
James
