O-RC1 Remote not working with K5 or K7
Posted 06/12/2012 - 14:55
Sounds as though it's incompatible with both these cameras, Andrew. Either that, or the battery in the remote has gone flat.
Posted 06/12/2012 - 15:20
I think it's probably the battery. It is compatible with the K-7 and K-5.
Posted 06/12/2012 - 15:24
Andrew, I was thinking along the lines of you having accidentally pressed the RC button with a heavy object when it was stored away.
Does the manual for both cameras suggest compatibility?
Posted 06/12/2012 - 15:31
FWIW, to test IR remotes, just point a cheap digital camera at it.
Most phone cameras are IR sensitive, and pressing the button should show up nice and bright in the phone image
Posted 06/12/2012 - 16:33
You have set them to fire remotely using the four-way button I assume?
Posted 06/12/2012 - 17:54
The battery on mine has just expired, a mere 17 years. I'll complain to Pentax
Posted 06/12/2012 - 17:57
That must be the F though not the o-rc1.
Posted 06/12/2012 - 18:20
Yep indeedy!You have set them to fire remotely using the four-way button I assume?
But what I have just noticed is the red light on the body starts flashing as soon as I select remote as the shooting mode....
Posted 06/12/2012 - 21:33
Yes that's right - it's to remind you it is in that mode.
Posted 06/12/2012 - 22:26
Gwyn wrote:
Still not working though
Yes that's right - it's to remind you it is in that mode.But what I have just noticed is the red light on the body starts flashing as soon as I select remote as the shooting mode....
Posted 07/12/2012 - 10:02
Then I think it is the remote which is broken. I have heard of others of that sort just giving up the ghost, and after only a few uses too.
I don't know how old yours is but it may be worth seeing if you can get it checked under guarantee/sales of goods act.
Posted 07/12/2012 - 13:35
Could it have been pressing against something in your bag and flattened the battery?
Chesterfield
I last used it before the summer both with my Kr and K200d - but today it has no interest in either of my cameras.
Any thoughts?
PPG link
Flickr link
