Nikon to Pentax adapter
Substitute
Posted 16/10/2007 - 10:14 Link
This is it: has anyone heard of an adapter to fit an Nikon mount AF lens to a Pentax body (K10D)?
I found a sigma 70-200mm Nikon mount as it is impossible to get a Pentax mount...and would need to use it on a K10D
ZaphodB
Posted 16/10/2007 - 11:16 Link
Sorry, no. I'm sure some Chinese eBay sellers have an adapter (they have ones for virtually any combination regardless of how well they actually work)... but you would lose infinity focus.
Plus the obvious: You'd have no autofocus and would have to use stop-down metering... which would rather defeat the point of having the fast lens
Do you know where your towel is?
Substitute
Posted 16/10/2007 - 11:27 Link
You're totally right...I am just considering options here:
I've been looking for a decent affordable fast lens for ages..and nothing showed up.
But I see plenty in Nikon fit or Canon fit...so maybe I'll sell my Pentax gear after all!
ZaphodB
Posted 16/10/2007 - 15:50 Link
Hehe... you're not alone there. I did just see the Sigma (DG version) go on another Pentax forum, a day after it was listed. I believe it went for near the price of the new improved closer-focusing HSM one for the other mounts
Personally I still much prefer Pentax overall, especially their camera bodies with the build and feature set they have for the price... and I still have that fondness for Pentax glass (up to and including the FA series anyway)... it will really take a lot to make me switch, so I enjoy using what I can, while I also continue complaining about the stuff I can't get until I can.
On the other hand if you need long fast glass, e.g for important events or professional work, then I can see you might not have much choice. But if you can, I would wait until the New Year at least... the latest rumours have something happening in January... also Tamron's own 70-200mm f/2.8 is also (again unconfirmed) said to be coming before too long. So to my mind it's still worth waiting a bit longer.
In the meantime, the only current option I can think of is the new DA* 50-135mm f/2.8. It does look very good, as long as you are happy with a 70-200mm "digital equivalent" instead of a 70-200.
Substitute
Posted 16/10/2007 - 18:30 Link
well..
I saw one on the US Pentax Forum, but the guy wanted millions for it!
It was not even the Macro one...
Shortage definitely makes prices increase but I am still reluctant paying way too much for those Sigma lenses...the are almost the price of my Zeiss primes....what a sick joke!
Let's wait and see what comes up, who knows they may realize that some pros have small women hands (as they are women!) and need a light camera like the K10D and that those same pros need a wide array of lenses...
Reuben0
Posted 16/10/2007 - 19:43 Link
You can get a manual focus adapter fairly easily.
Unfortunately, because the Nikon lens to film distance is 1mm more than Pentax, you lose infinity focus.
I got one to allow me to use a Nikon telephoto on my Pentax cameras and the lack of infinity focus makes no difference for my use of it.
R
Terrance13
Posted 23/10/2007 - 20:42 Link
I'm also curious about this.
We don't have to always lose infinity focus, do we?
The Pentax flange-to-film (or flange-to-silicon) distance is 45.46mm.
The Nikon distance is 46.50.
So the distances are right -- the Nikon distance is greater than the Pentax distance.
An adapter that will focus to infinity is theoretically possible, unless there is an issue with throat diameter. If the Nikon lens won't fit into the diameter of the Pentax hole, then that creates a problem.
But I don't see the problem. I just happen to have the required parts for the test in my hands because I'm one of those guys who loves to collect legacy lenses and use them on a new digital camera with adapters.
A Nikon N/AI lense just went into the socket on a Pentax-K 2X doubler, so throat diameter cannot be the problem. Now the prongs on the bayonet mount are not exactly correct, so it won't twist and lock. I also see a small black "bump" or prong sticking out of the back of the Nikon lens that is getting in the way. Maybe grind that off?
Is hacking the Nikon lens to permanently adapt it out of the question?
(That is a personal decision, and depends on whether you wish to ever use the Nikon lens on a Nikon camera again.)
** A fanatic is a man who consciously over-compensates a secret doubt.
** == Aldous Huxley
Kim C
Posted 23/10/2007 - 20:53 Link
Some adapters will not lose infinity but others will. Even if the flange/film plane distance is greater, they may not be room for the adapter. SRB do a large range of adapters and some have an lens in to correct.
Kim
Reuben0
Posted 23/10/2007 - 21:52 Link
I
This is exactly the problem - the Nikon F lens mount is more or less the same diameter as Pentax K and almost the same distance from the film plane. This leaves no room for an adapter
M42 -> PK works because the M42 diameter is quite a lot less and so the adapter can fit inside. M39 -> M42 works because the adapter is very thin, as it's just joining 2 screw threads.
I
It is possible to directly mount a pre-AI Nikkor on Pentax. Some of them even lock in There was a thread about it on DPR last year by Sean Carpenter.
Unfortunately, none of my AI Nikkors will mount though, hence the adapter...
R
