Nikon is going EVIL
Anvh
Posted 10/07/2010 - 18:28 Link
Like the title says Nikon is going EVIL, probably before March 2011.
If you think I'm joking read this link
This what the rumours say about the new system. link
When will the rest go EVIL as well?
Stefan
K10D, K5
AF-540FGZ
Posted 10/07/2010 - 19:54 Link
I think EVIL is a nice bridge between DSLR and point-n-shoot. I don't mind that they exist, personally. The more options, the better!
flossie
Posted 10/07/2010 - 20:25 Link
I like the patent for a cover over the sensor when you change lens.
The more mysterious thing is - why has it taken 10 years of DSLR's for someone to come up with this?: It wasn't so much of an issue with 35mm SLR's because you moved-on to the next frame, and with Film you have a camera assistant with a can of compressed air...but with digital its spawned a whole industry for keeping sensors clean (as I've found out to my cost...no the artic butterfly still hasn't arrived... waves fist vaugely at SRS, hope my work pictures yesterday came out ok haven't dared look at them yet...)
Oh, sat next to someone on the tube with a D700+Grip getting from job 1 to job 2... It seemed to be a bit of jewellery to go with his expensive rings and necklace - certainly wasn't using it to take any pictures... I knew it was a D700 because the strap said so in HUGE letters...
Anvh
Posted 10/07/2010 - 20:37 Link
Flossie, the shutter is actually closed when you've not pressed the release button with (D)SLR so no need for a cover over the sensor because only when you press the shutter dust can go onto the sensor.
Sigma has solved this problem by placing a filter in the lens mount on the camera so no dust can go inside the body to begin with.
It could be the new Nikon might use an electronic shutter so that might explain the special cover to protect the sensor.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 10/07/2010 - 20:41
flossie
Posted 10/07/2010 - 20:47 Link
Really? so what's this great gapeing hole that sucks up dust/pollen/dirt/hairs/dandruff then...
Hmm, oh thought that what was the Nikon patent was all about, then again if its a US Patent prior art isn't a consideration anyway...
Anvh
Posted 10/07/2010 - 20:57 Link
That's the lens mount not the sensor.
The shutter is placed just before the sensor so you need to move the mirror up to see it properly.
If you don't believe me about the shutter resting position do a 2 second delay with your lens off.
With the two second delay the camera will flip the mirror up and you can see the shutter in action.
Sigma has done it different, it's really just a filter instead of a cover that moves away when the lens is on.
It's a filter that cuts UV and IR light and you can remove it if you want to do such kind of photography, quite smart if you ask me.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 10/07/2010 - 21:18
flossie
Posted 10/07/2010 - 21:37 Link
yes i know technically the shutter is back there...but practically you need a cover at the front so crap can't get inside when you take a lens off.
In fact, with about 2 seconds thought I can come up with an Iris-shaped cover mechanical mechanism attached to the lens-mount release button that is permenantly open when a lens is attached but closed if nothing attached, no clever electronics involved...and I'm sure camera designers could do something better!
