Need lenses for K10D
Posted 29/08/2008 - 11:25
What's your budget?
How wide do you want your wide angle lens?
Older fisheyes are going to be designed for 35mm, so won't have such an exagerated effect on your K10D, definitely better off with the 10-17mm.
Macro lenses are often discussed on here, just about anything by Pentax/Sigma/Tamron will give you good results. Even the Cosina type (100mm f/3.5) aren't bad at all, and can be picked up cheaply. Or if you got a 50mm f/1.7 lens, you could use this with extension tubes for good results.
But without knowing your budget, answers will be limited.
Dan
Dan
Posted 29/08/2008 - 11:33
There's a general feeling that lenses older than the "A" series aren't worth having on a DSLR because the camera can't set the aperture and consequently everything has to be done manually (in addition, the K10D can give somewhat flaky meter readings when the lens is used in any way other than fully open). Because of this, "M" series and earlier lenses tend to swap hands for peanuts and this is where you'll find some bargains.
The M50/1.4 is a great low light / portrait lens with stunning optics that can be picked up for around the £25-30 mark.
The M50/1.7 can be had for even less (around £10-15), is half a stop slower than its 1.4 sibling but has a flatter field meaning it's better suited to macro work. Get one of these and some macro tubes and you've killed two birds with one stone! Better yet, you should have change from 30 quid.
Can't think of any dirt cheap fisheyes I'm afraid, but you could always look out for an old fisheye convertor (the kind that screws in like a filter) - they tend to be quite poor quality though.
Joining the Q
Posted 29/08/2008 - 12:20
M42, K and M series lenses work fine on any Pentax DSLR (exposure mode set to M). . . if you also own a light meter . . . and use it.There's a general feeling that lenses older than the "A" series aren't worth having on a DSLR because the camera can't set the aperture and consequently everything has to be done manually (in addition, the K10D can give somewhat flaky meter readings when the lens is used in any way other than fully open). Because of this, "M" series and earlier lenses tend to swap hands for peanuts and this is where you'll find some bargains.
It's pushing it a bit to expect 21st Century technology to be backwards compatible to the mid 20th Century. Pentax has done their best (and better than most) to maintain compatibility, but the rest is up to the user.
Posted 29/08/2008 - 14:28
Picked up a 50mm 1.7 for a ten pounds and seen a few on ebay.
Posted 29/08/2008 - 15:24
iceemn360 wrote:
Hey Everyone. Im a college student on a budget. I currently have the Pentax k10d with the DA 18-55 kit lens as well as a 70-300 Quantaray Telephoto/Macro
I was looking at some of the FA and older film lenses and other primes. Knowing that the k10d can take any K mount lens... what Good but cheaper lenses from the past production lines can I use with good results. I am looking for a Prime in the 50mm region as well as a better wide angle lens to sub in for the kit lens. Any suggestions? Oh and I also was thinking about an older fish eye and a macro lens. Any help is greatly appreciated!
The Pentax-A 50mm F1.7 would be ideal for you. It provides a reasonable combination of quality and convenience while saving money - which you will need for the wide angle.Hey Everyone. Im a college student on a budget. I currently have the Pentax k10d with the DA 18-55 kit lens as well as a 70-300 Quantaray Telephoto/Macro
Wide angle choices are more restricted because of the crop factor. Lenses that are wide on film won't be on your digital camera. This means that you will have to get a more modern lens if you want ultra wide.
~Pete
Posted 29/08/2008 - 16:46
There is none better than the Russian Zenitar 16/2.8, super-sharp, well-made and cheap. I also was thinking about an older fish eye
Although on an APS-C crop DSLR (in common with all full-frame fish-eyes) it's really more of an ultra-wide lens with a lot of barrel distortion
R
Posted 29/08/2008 - 18:04
lol oh sorry. Budget per lens would be about 150-200...
Posted 29/08/2008 - 19:40
Call that a budget? Things were different when I was a student.lol oh sorry. Budget per lens would be about 150-200...
Posted 29/08/2008 - 20:12
You may need to spend over 300 on the wide angle, but you can economise on the 50mm and macro to fund it.
~Pete
Posted 30/08/2008 - 00:06
wow thanks for all the feed back guys!
Posted 30/08/2008 - 00:33
Well the Zenitar can be picked up new for £99 (+p&p) which, as Reuben says above, will give you a wide angle with quite a bit of barrel distortion - nothing that can't be sorted in PP though. I don't know if it would give better results than the kit lens but it will be 2mm wider, half a stop faster and useable on 35mm film (or a future "full frame" sensor).
That still leaves you some change for an M50/1.7 and a set of extension tubes.
Joining the Q
Posted 30/08/2008 - 10:16
In my opinion, the de-fished the Zenitar is a lot better than the kit lens and there are many example shots on the "other" Pentax forum for you to make up your own mind I don't know if it would give better results than the kit lens but it will be 2mm wider, half a stop faster and useable on 35mm film (or a future "full frame" sensor).
It's also a lot wider than the apparent 2mm difference would suggest - the de-fishing process effectively stretches the frame out wider and thinner.
I've also compared the Zenitar against my DA 10-17 fisheye at 16mm and the Pentax is rather embarrassed by the Jurassic Russian offering!
R
