ND filter advice for DA Ltds
Posted 05/05/2011 - 08:23
jules wrote:
For the Lenses you've got and I'm thinking of the 21mm here try em out before you buy!
I love my screw ins, no going back now, fits all the Ltd's and the holders built in!
I had a HI-Tech (Formatt) System and found it unworkable/PITA
Thanks JulesFor the Lenses you've got and I'm thinking of the 21mm here try em out before you buy!
I assume your screw ins are soft grads? It's not totally clear from the Hilton website....
Posted 05/05/2011 - 20:19
APS_C sensor is quite a bit smaller so a soft will be extra soft so a hard GND might be better but you need to find that out for yourself.
Posted 06/05/2011 - 10:15
The one stop isn't very harsh at all and you can pretty much get away with putting the Horizon anywhere, the two stop is much more dramatic and they advise putting the Horizon in the centre if you can, I have so far followed this an have had no problems...
Cheers Jules...
Posted 06/05/2011 - 10:48
Thanks again to everyone for contributions - really useful
I've decided to try Jules' screw-in grad solution, and have just ordered the one-stop from Hilton (the two stop wasn't in stock, which given the cost is probably a good thing until I've played with the first one!).
Depending on how I get on with this I could end up looking again at some sort of square filter system but (as per Matt's post) the main reason I'm investing in the Ltds is for portability... so I suspect even if it's not perfect I'll end up taking the screw-in out routinely on hikes etc, which is when I'm doing most of my photography at the moment.
Posted 06/05/2011 - 11:23
My situation was similar and my conclusion too. Possibly not Ideal but it is a good compromise...Everything is a Compromise...
Cheers Jules...
Storbritannia
I was just indulging in a lunchbreak google graze of filter systems when all this new activity struck. Thanks for all these useful comments!
There are essentially two issues here. Firstly, would you prefer to faff around in the field or faff around in front of your computer? Secondly, do you also shoot film?
K.
Digby22 Wrote: The ND Grad filters I have are 100mm wide (they are just a flat piece of plastic) so they are easy to hold in front of the lens, but it takes up a hand, so only really practical with a tripod.
Did your 0.9 ND grad come from the Hitech ssytem as well?
Yes because you can reverse mount the holder so it will only hold a single filter.
This should link you directly to the page of the z-pro.
http://www.cokin.fr/ico15/ico15-haut.html?=#z
Recommended for focal lengths from 20mm onwards (35mm format)
I don't think you can fit it on the DA15 though because the hood doesn't redraw fully...
ps. the z-pro filters surely aren't the best there is, there is still a slight magenta cast but it's less then with the A and P serries.
I believe Matt also has these filters.
