My first Problem with the K10D DUST !! please read
petekd
Posted 05/02/2007 - 12:51 Link
Hi all
Welcome back after the forum being down for the weekend
Any way yes i have have it DUST !! on the k10D sensor for the second time on a camera only a few weeks old. The first camera i just took back to the shop as i wasnt sure it was dust being new to DLSR, Jessops changed the camera for me no probs. Now i have the same problem again and it wont go even after a few dust cleaning goes with the camera itself.
It is showing as a small round sphere in the top right of my pics and started yesterday. Strange as i did not change the lense or expose to the elemnets. I also too a photo of white paper which apature 22 and it shows more clearly and sharp.
So the K10D dust removal is not perfect. I did not expect it to be as im not sure any dust removal system is. However i did not expect it so soon and especially without changing the lenses. Below is a photo showing the problem. I read somewhere the pressure inside the camera creates a type of vacume when the lenses are zoomed in and out whic can disturd or creat dust but not to sure about this theory.
Can anybody tell hows best to get rid of this , should i use a big blower. I dont really want to take it back to Jessops and be charged for this small bit of dust being removed. I know its not a major issue as i can remove it in post processing but re saving jpegs lowers quality and not something i want to do evertime i take a pic. Also I know i can hear some of you shouting better to a pay a few quid than break the camera sensor, but if this is going to happen regular i prefer to risk it with a good cleaning kit and good advice. What i need is the best and safest method of removal by you guys who are used to this thing with older DSLR and SLR cameras
All advice welcome
Pete
[/img]
Rodger Fooks
Posted 05/02/2007 - 12:57 Link
Posted 05/02/2007 - 13:00 Link
If dust is going to fall on the sensor, then whether the camera's a week or a year old fall it will. However, with our *istDS bodies we were very lucky and never had to clean the sensors.
If it annoys you, why not try the blower brush method. But first I would set the camera to perform dust removal at every start up for a while and then see if the dust is eventually dislodged.
Posted 05/02/2007 - 13:05 Link
I always have dust. Lots of it.
On the *ist-D I had platefuls of it and even with careful cleaning it seemed to creep back in. Having seen Keith Henson's CCD (ephotozine user "keithh" on his Canon 1DsMkII I don't worry so much - his was the dustiest sensor I've ever seen Just takes a minute to clone out with the patch tool in Photoshop.
Anyway, back to the K10D - my current process is:
1. Try the built in dust removal that shakes the sensor. This works most of the time.
2. Use the sensor cleaning option (which allows manual cleaning) and blast with a rocket blower. Don't use canned air. This got rid of my dust spots (which were larger than your example).
3. If all else fails - I'll use the manual clean. Pentax sell a kit for this. I've used other kits for the *ist-D and *ist-Ds and it's not that difficult, just nerve wracking the first time But, so far, my K10D hasn't needed this.
I've heard of people saying they have never had dust at all But my personal experiences say you can never get away from it 100%, and at the end of the day a single spot is no big deal in Photoshop or Elements
petekd
Posted 05/02/2007 - 13:37 Link
thanks guys
Mannesty
Posted 05/02/2007 - 13:42 Link
That may well be the case if they have only one lens as it's never removed from the body.
So I have a suggestion:- Buy a K10D body for each lens in your collection, then you'll not get dust.
Don
Posted 05/02/2007 - 13:52 Link
Pete, I'd worry more about that big arrow.
It really sticks out.
I might not have even noticed the dust spot, if it weren't for that big arrow.
What could cause such a thing?
Marks on the sensor? Confused sky writers?
I have to tell you that we have lots of lenses and we change them, but always in a dust free area (as far as possible and always quickly and carefully.
I find it quite surprising that we all have such widely different experiences of this. But we do, so I guess that's just the way of things!
amoringello
Posted 05/02/2007 - 14:06 Link
Pete, The Rocket Blower did the trick for me as well.
I do have to say, the K10D sensor is otherwise spot free. Even with manual cleaning, the istD never got completely clean. If all I need to do is blow some air for the big stuff, I can certanily live with that!
Matt, I have a sensor cleaning kit (solution and swabs) that I used for the istD. Any ideas on wheather this would be acceptable in lieu of the Pentax kit? Or is there something special Pentax requires in combination with its floating sensor mechanism?
I'd hate to buy another kit, but I also don't want to experiment on my new K10D.
alfpics
Posted 05/02/2007 - 14:08 Link
Pete,
If you use a blower, make sure you use a Rocket Blower with a one way inlet valve. I used a bog-standard one once - all it did was add loads more dust particles on the sensor, giving a black snow-storm effect!
When the blower doesn't work, have personally used Digi-pads and eclipse fluid, but am sure other brands work as well.
As Matt said above - nerve-racking the forst time you do it, and you must make sure the battery is fairly well charged in order to keep the shutter open whilst poking around inside!
Andy
( LOL at Don!)
Daniel Bridge
Posted 05/02/2007 - 14:21 Link
I recently did some product shots for a customer, using my studio flash and aperture of f/16, with a white background. Should have given the sensor a quick blow first and saved myself having to clone out numerous spots and a line (a small fibre) from every shot. Stupidly I packed everything away before I processed the shots, so didn't notice until too late - probably would have been as quick to reshoot them all.
I'd been happily using the camera the day before, and there's virtually no sign of the dust of these, as most were taken with an aperture of F/4 to F/8 with a mixed background.
Don - you crack me up!
Dan
petekd
Posted 05/02/2007 - 16:09 Link
Yes you would think this would work BUT i got dust and didnt even change the lense
Nice one Don LOL like the sense of humour perhaps ill make the dust spot into two eyes and anose next time
Posted 05/02/2007 - 16:35 Link
Pete,
Most modern zooms are not sealed. So when you zoom in and out the air has to go/come from somewhere - and it's this process that can suck in dust.
Additionally, the cameras are not produced in cleanroom environments - they are shipped minus the lense and so at any point there could be some dust in the chamber. It might be shipped with dust on the CCD already, or internal dust can be dislodged during use and find its way onto the CCD.
LiamD
Posted 05/02/2007 - 18:09 Link
Thud....
That's the sound of George fainting..
Liam
Liam
Mannesty
Posted 05/02/2007 - 18:14 Link
Don't worry, he'll come round with a drop of Bowmore . . .
