More rumours
Posted 10/02/2012 - 23:12
Hmmm, Pentax FF. Let's see if it does appear. May make use of my 15mm, shift and Ltd's yet?
Posted 11/02/2012 - 01:04
Pentaxophile wrote:
Ricoh plans black and white compact. Interesting idea! Ricoh is already quite popular with b&w street shooters.
the k-01 comes in black and white...lol... just kidden I knew what you meant..!
Posted 11/02/2012 - 07:20
Mirrorless 645D is also an interesting idea,
If they use the 645D mount, presumably it will still be quite deep but presumably they could introduce a range of 645 XS MF pancake lenses. If it brings digital MF closer to consumer prices then I'm all for it.
Posted 11/02/2012 - 09:28
This has been posted several times already. It was just the
thoughts of a man from Ricoh, not official plans of
the company
the company
Posted 11/02/2012 - 11:40
There's no way they could keep five systems going all at once (Q, DA, FF, K-01, 645D) plus the Ricoh stuff Other manufacturers only have one or two!!! They are going to have to decide which basket to put their eggs in very shortly...... The DSLR's are currently being neglected.
Posted 11/02/2012 - 12:59
Pentaxophile wrote:
DA, FF, and K-01 aren't exactly separate systems though. Basically they've got Q, K, and 645 mounts.
Not strictly true as it looks like there will be K lenses that aren't mountable on the K-5/K-r due to their recessed element.DA, FF, and K-01 aren't exactly separate systems though. Basically they've got Q, K, and 645 mounts.
So we will have Q, K, son of K and 645
Posted 11/02/2012 - 17:00
One clue as to the likely hood of a FF could be in the specs of the 560mm when they are released – I don’t see the point of making it anything other than FF if Pentax have plans in that direction.
Posted 11/02/2012 - 17:26
I think they would struggle to make a 560mm lens that just covered APS-C. The DA*300mm covers FF so I'm quite sure that the 560mm will. If it's any good and cheap they may sell some to Canon FF users for use with an adapter.
Posted 11/02/2012 - 17:46
Camera-makers are seeing the traditional OVF pentaprism as on the way out over the next few years in favour of EVFs and hybrid stuff, so there may be more call for recessed lenses of the K-01 kind. A way round FF/APS-C would be to put a powerful FF Sony sensor inside and then allow APS-C lenses to use it via a mask system. This would still probably yield at least 16 megapixels in the smaller image circle, with the high-end boys using their FA limiteds and the like at FF.There's no way they could keep five systems going all at once (Q, DA, FF, K-01, 645D) plus the Ricoh stuff Other manufacturers only have one or two!!! They are going to have to decide which basket to put their eggs in very shortly...... The DSLR's are currently being neglected.
Another line of lenses to add to the mix are video lenses which really will become important to every camera-maker I'd guess.
Interesting times! At least Pentax now has an owner with deep pockets because they'll be needed.
South London
Make what you will of it.
