More Recent Shots
Posted 18/05/2014 - 15:20
In all of these the highlights seem a little blown out. That may be your thing, I dunno. If not is there facility on the K-x to prevent this or possibly consider dropping the exposure a tad?
I know that running a manual lens on the K-r I couldn't always trust the in-camera exposure. It was good but sometimes a notch out.
Love the stencil graffiti haha
My favourite is the last. Again though, I feel that reducing the exposure slightly might have brought out a little more detail in the sky. Problem I have from my end is that we may just have a difference in monitor output
As always...great to see your exploits.
Sometimes I'm serious and sometimes not, but I consider sarcasm an artform. Which is it today?
Posted 18/05/2014 - 16:02
I often dial in a -0.7EV when using manual lenses, just in case.
Posted 18/05/2014 - 16:04
Hi Steve
Your not the first to say that in the last few days. Perhaps its my taste because I never find it off putting. It is difficult however, as you know to expose for sky and ground, as one must suffer over the other. The manual lens MAY just tip it slightly and I will look at that more closely next time.
Thanks for the comment
Posted 18/05/2014 - 23:29
I like the compositions Alistair but I'm not sure that lens is doing you any favours. I found with my K-x when using manual lenses that I had to under-expose quite a bit to prevent blown highlights and it seems your K-x is not metering too well with this lens.
Also I've noticed that most of the shots you have posted with the 28mm F2.8 look quite soft, this is not a trait that your images with other lenses show. I hope this doesn't come across too critical as I do like the images, it's just that I think they would have been better shot with a different lens!
Posted 19/05/2014 - 03:24
QuestionableCarrot wrote:
Hi Steve
Not to any practical degree these days. Expose for the sky and there's plenty of dynamic range to bring up the shadows to give the "ground" a decent exposurewithout it being too noisy.
Hi Steve
Posted 19/05/2014 - 09:06
I agree of course Smeg on the sky technique but the K-x is a little shabby at regaining light in other areas. Im not averse to noise but its quite bad when you have to push it. I dont think the lens is that soft David but I accept where you are coming from. the DA 21 is on the cards at some stage!
Posted 19/05/2014 - 12:39
Why not get yourself a K-5 ?
Posted 19/05/2014 - 14:17
I have a Kx and a K5 and find the Kx produces images almost as good as the K5, particularly at high ISO...very clean and almost noise free.
Do I have a particularly good example?
Regards,
Michael
Michael
Posted 19/05/2014 - 17:42
I have a k5 just use the kx as my everyday camera.
Posted 19/05/2014 - 17:43
I think the first three photos are great but then I would say that .
