More experiments with reversed 50mm lenses
Posted 17/06/2013 - 18:34
Very good Peter! I'm not sure which is best from these images, but I can I can confirm the M 50mm F1.4 is excellent reversed too.
Posted 17/06/2013 - 22:31
Mannesty wrote:
Thanks David. Didn't you make the same point about your 50mm/1.4 lens here?
Do you have any images to show us taken with your 50mm/1.4 lens reversed?
Hello Peter, yes you're right I was referring to the same lens. I haven't taken many interesting shots with it but here is one example:Thanks David. Didn't you make the same point about your 50mm/1.4 lens here?
Posted 17/06/2013 - 22:38
They're ugly beasts close up 'n personal aren't they.
Nice capture. It's too hot here at the moment for our local fly population to sit still for very long.
Fortunately (apart from the incessant noise) the Cicada season will soon be upon us and I hope to get some stacked shots of them towards the end when they become a bit more lethargic.
Posted 18/06/2013 - 07:59
I should add that these shots were taken with the two 50mm lenses reverse mounted on bellows. The schneider image was taken with the bellows at full extension to get the highest magnification. The Pentax image was taken at minimum extension to get most of the mantid in the frame. A 28mm lens reverse mounted in this way gives incredible magnification, but paper thin DOF.
21 years
Totana,
Spain.
First up,
Schneider Kreuznach Componon-S 50mm/2.8 enlarger lens - untouched image
This crab spider was about 2.5 - 3mm from top of head to tip of abdomen
K51_8469.jpg by Peter E Smith (AKA Mannesty), on Flickr
Reworked version
K51_8469-Edit.jpg by Peter E Smith (AKA Mannesty), on Flickr
smc Pentax-M 50mm/1.7 standard prime lens - untouched image - Unfortunately the crab spider disappeared between lens changes.
This praying mantis was about 15mm from top of head to tip of abdomen
K51_8484.jpg by Peter E Smith (AKA Mannesty), on Flickr
Reworked (scary) version (maybe a little overdone, or even a lot overdone)
K51_8484-Edit.jpg by Peter E Smith (AKA Mannesty), on Flickr
