More Ektar shots.
Posted 18/08/2012 - 15:01
My favourite colour film now that I don't shoot slides. Those are big scans, especially for the price! I see the Rosebay Willowherb is doing well down your way too. K.
Posted 18/08/2012 - 18:03
I really like the colour nuances of your Ektar images. You are fortunate to get such great scans for that price! I have currently used mostly Kodak Porta 400 for my 6x7 attempts, but I also have some rolls with Kodak Ektar 100. Seeing the great resuls you have gotten here, I am eager to shoot some rools of Ektar 120 film.
Bjørn
Bjørn
Posted 18/08/2012 - 18:56
Damn, I miss my Samyang 85. Very nice photos sir!
Posted 19/08/2012 - 12:08
Thanks for the comments chaps. I found it quite interesting that, unlike digital shooting, shooting with Ektar and my PZ70 delivered perfectly exposed images, with colour and contrast which was very pleasing straight out of the can. Look at the woodland shot. There's no way a DSLR could produce an exposure like that without quite a bit of tweaking in PP.
Posted 19/08/2012 - 18:02
They should send you 16bit TIFFs really so there's no compression artefacts and more dynamic range to post pro with.
Just had a look and my neg scans are about 5060x3360 and a 16bit TIFF file is about 120Mb. Scanned at 3600 dpi. The scanner does do 7200dpi but it produces 500Mb files and way exceeds the res of the film.
Love those B&W shots btw - and Awwwwwww at doggie
Posted 19/08/2012 - 22:40
Posted 02/09/2012 - 19:26
I love Ektar 100, has such an amazingly wide (and forgiving!) latitude. This is the only colour film i use now.
Posted 29/09/2012 - 23:41
I used to get my negs scanned onto cd but found that when I got them back they were to over processed for my liking. I invested into an Epson V600, I really wanted the V750 but I don't shoot enough film to justify the cost. I generally scan my negatives at 4800 optical dpi and my 35mm files end up about the same size (around 6500 pixels at the widest end) and my medium format negs end up around 9200 pixels at the widest end. Obviously it takes a while to scan in all the negatives, do any dust removal/scratch removal but for me it was worth investing into a decent scanner.
All in all though I think they've done a very good job with the scans and the price isn't bad either
Howie
Howie
Posted 30/09/2012 - 09:29
The K-5 is very good for photographing slides (not tried negatives)
and you get a RAW which can be manipulated quite a bit.
HDR may also be possible from several shots.
It doesn't pick up all the dust that scanning does
especially if you use a diffused light source, which
was the way to go with enlargers anyway.
Posted 30/09/2012 - 10:31
Diffuser enlargers do indeed pick up less dust from a negative, but at the cost of a little contrast and sharpness. Condenser enlargers are sharper and more contrasty, by as much as a whole paper grade.
Posted 30/09/2012 - 11:02
Condenser's also lost a lot of highlight detail which might
not matter too much with 35mm, because it had 1 Zone less on
the Ansell Adams scale than 6x6 and larger, but it was
noticeable on the larger formats such as 6x7.
The exposure times were longer as well with diffusion.
I've still got a Super Chromega D700 6x7 diffusion enlarger
although I've not used it for years.
Posted 30/09/2012 - 11:33
This is a straight copy of a Kodachrome slide with a Pentax_A 50mm f/1.7 on K-5.... took only a few seconds
to copy each slide using the Pentax K Slide Copier.
Lighting was a large energy saving globe light (3200K) CB set in camera.
Slight alteration to CB no other PP or sharpening.
Taken in Seville 1972 Spotmatic II with 50mm f/1.8 lens - Kodachrome
Nottingham
Developed and scanned by Snaps Photo Services - for 7.50 I got a CD with 36 23MB jpegs, scanned at 6774x4492 pixels!
A close up of the grain at near 100%. The scan resolution exceeds the resolution of the film, I think. I'm very happy with the quality of the scans.
Other Ektar shots:
I also had some old HP5 film to use up.
