Mixing batteries in camera/grip
Posted 28/05/2009 - 13:25
According to Pentax it will probably explode, taking out your camera, house, family and friends with it.
In truth, providing you buy from a UK retailer and it has an EU standard it shouldn't be a problem. After all, most of the Pentax Pro stockists will sell you a generic battery which they wouldn't if they thought they would harm your camera (and thereby their reputation).
I would be wary of eBay or buying from overseas. Many of these products may appear OK but are often of a lower standard.
As for mixing batteries, That shouldn't be any sort of an issue.
Posted 28/05/2009 - 13:26
I have used none genuine from www.7dayshop.com and SRS for years inc' Pentax K20D and my Canon 50D never had any problems what so ever.
Tel,
Posted 28/05/2009 - 13:36
Shouldn't make any difference, the camera auto selects the battery with most power, on saying that I never use a battery in the camera, I only use the battery in the grip to save removing the grip every time the battery goes down, I always carry 2 spare batteries at all times and their different makes anyway.
Jack.
Jack.
Posted 28/05/2009 - 13:45
I echo the comments above. I purchased a generic Pentax Fit 1750 mAh battery with my K10 and in truth I use it more than the original. It charges with no problems in the Pentax charger and on average gives me around 100 extra shots per charge
Posted 28/05/2009 - 13:59
I ound this one from a forum search. Seems incredibly cheap! http://www.7dayshop.com/catalog/product_info.php?cPath=777_3&products_id=99219
Does it matter that the 1500mAh is different from the Pentax one (1620Ah), and will it work with the original charger.
Many thanks.
Many thanks.
Posted 28/05/2009 - 14:01
there perfect alot of pentax forum members use them,
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 28/05/2009 - 14:06
Many thanks.
Should not be a problem,as long as the voltage is the same. The Pentax charger does have trouble with some of the higher rated batteries . I have seen some from Germany as high as 2500mAh, They are more expensive but are said to give very good performance and are usually sold with their own charger.I ound this one from a forum search. Seems incredibly cheap! http://www.7dayshop.com/catalog/product_info.php?cPath=777_3&products_id=99219
Many thanks.
20 years
Surrey
My existing two batteries are both Pentax original K10 products.
Any thoughts on me getting a non-genuine Pentax battery, and especially will it present a problem mixing them in the camera/grip combo ?
