mirror sticking on MZ-7
I don't know the age of your lady's MZ, but would this be a possibility?
Was the camera cooler/colder than usual? I've had the Spotmatic family's lubrication thicken/gum up in cooler weather, and have sent the bodies to be serviced.
However, this is only supposition. I am quite happy to fiddle with the older mf cameras but at this level it is an experts job.
Kim
I havent stripped an MZ, but I doubt the mirror is motor driven. Usually even with electronic cameras the shutter and mirror are still spring driven. The shutters are released using little electromagnets to activate the the mechanical latches that hold them cocked. The rest is mechanical, as in a manual camera.
I suspect that what may be happening is that the shutter is not being cocked due to some mechanical problem. This would explain the stuck mirror, as mirror drop is triggered by the closing shutter.
This could explain the heating effect, if the camera is waiting for a signal that the shutter is cocked before it switches off the electromagnets to fire the shutters.
20 years
my girlfriends MZ-7 started misbehaving last weekend. it'll be fine for a few frames, then the mirror will remain up after the shutter has closed. the film doesn't advance... the whole things just jams up. the mirror can be pushed down again by hand, but just flips back up. once the mirror is in this position, the camera is totally unresponsive. if the batteries are left in the camera while the mirror is 'up', something gets very very hot inside the body, including the batteries. the only way to get the mirror down again is to leave the camera for the best part of a day with no batteries in. after this, once the batteries are replaced, the mirror pops back down, the film advances and it's all back to normal, but only for a few more frames before it all starts happening again.
any ideas??
many thanks...
chris
