mirror lens
jacqui2
Posted 12/02/2011 - 23:30 Link
Hi, could someone tell me what a mirror lens is? I have seen these on ebay and such but don't know anything about them, only ever used the basic kit lenses with my cameras, also, would these be suitable to use with my k-x? thanks.
jacqui
Oggy
Posted 12/02/2011 - 23:44 Link
Long story short -
It is a layout for making long lenses small and light. On the downside, there is usually a price to pay in terms of image quality, they tend to be fixed aperture ( usually F8 ) and some of them produce a weird doughnut bouqeh.
Edited by Oggy: 12/02/2011 - 23:44
K10D
Best have a read here. Quicker than the next few posts.
link
rscoote
Posted 12/02/2011 - 23:50 Link
Hi Jacqui,
Mirror lenses are long telephoto lenses that include two mirrors as well as lens elements. Light enters the front element and is reflected off a large, concave forward facing mirror at the rear of the lens that directs the lens to a small rear facing mirror at the front which, in turn, reflects light through the aperture. This reduces the physical length of the lens by about a third, as well as the size and weight, making it much easier to handle.
There are a couple of drawbacks however. First the aperture is usually (always?)fixed, for example 500mm f/8, so it cannot be stopped down and the bokeh is unusual so that out of focus highlights are actually rings.
The only challenge on K-x is getting the correct exposure but with a fixed aperture I think that should be pretty easy. Someone with a K-x and experience of using a mirror lens on it may be able to give you detailed instructions.
Regards,
Roy
My PPG link
K-3, K-5 + D-BG4 Grip, Pentax: FA 50 1.4, DA* 300, Sigma 70-200 2.8 Macro HSM II, Sigma 18-50 2.8 EX DC, Metz 58 AF-1
Dangermouse
Posted 13/02/2011 - 00:04 Link
It would probably work best if you set the camera to Av mode and use an ISO which gives sensible shutter speeds (1/500 or better is the usual guide for a 500mm lens).
They do have limitations, the f8 ones will be very dark and tricky to focus while the f5.6 ones are likely to have very shallow depth of field. You can get great results but I'm not exactly rushing to buy one as it seems hard to get a straight answer about picture quality rather than the "it isn't £800 so it must be junk" reviewers.
jacqui2
Posted 13/02/2011 - 00:08 Link
ok thanks guys, the one I have seen says samyang (??) 500mm f6.3 mirror lens £109.99 3 year warranty. that's about all I know about it. (camera centre cardiff).
jacqui
Edited by jacqui2: 13/02/2011 - 00:08
Smeggypants
Posted 13/02/2011 - 00:24 Link
Wonder if the Bubble Telescope comes in K mount ? And if there's a macro version
petrochemist
Posted 13/02/2011 - 09:40 Link
Smeggy, I'm guessing your fingers missed - Did you mean Hubble?
In which case you could get an adapter, but getting to the lens proves expensive .
Macro is definitely out!
Dangermouse
Posted 13/02/2011 - 10:07 Link
Samyang have good build quality and make some excellent lenses, I haven't tried their mirror lens though so can't comment. My advice would be to go to the shop with your camera and ask if you can test it with a view to buying. A quick shot of the brickwork on the shop over the road from the door should give you some pointers, although you really need a tripod to get the best from long lenses.
DoctorJeff
Posted 13/02/2011 - 10:21 Link
Got two of the things. One in K-mount (an original T-mount, ie not T2) and one in M42. Cannot remember when I last used either of them.
A 300mm hung on a K200 has reached as far as I have wanted to.
Geoff
X-5
istDS
K2000
P50.
thoughton
Posted 13/02/2011 - 11:40 Link
You've had lots of answers I see, but I'll just throw in my 2c. I've owned the Tamron Adaptall-2 500mm f8 mirror and MTO 1000mm f11 mirror.
500mm f8 mirror lenses have a shorter DoF than a 300mm f5.6 lens, not the other way around. The longer focal length more than makes up for the smaller aperture.
Samyang and associated brands (Rokinon, Opteka, etc) mirror lenses have a decent, but not brilliant, reputation. The Tamron on the other hand has a great reputation. If you're thinking about spending £110ish I would be looking for the Tamron instead. (It should possible to get one for around £125 or so, but you'll have to look for a while. Avoid the rip off Buy-It-Now outfits on ebay who want £200 for this lens).
Tim
Edited by thoughton: 13/02/2011 - 11:46
Blythman
Posted 13/02/2011 - 12:19 Link
Eider Drake Tamron SP500mm
Swan Tamron SP500mm
Hi Jacqui. The Tamron is an excellent lens, that can produce excellent photos. I can't speak for other lenses. There are limitations with it though. Out of focus highlights can produce a "doughnut" effect also if the subject is close, as opposed to isolated from an out of focus background, the bokeh can be messy.
There is a group on flickr for mirror lenses mirror reflex
Alan
jacqui2
Posted 13/02/2011 - 12:48 Link
ok thanks everyone, Im not sure if this would be right for me.I am just wanting more zoom, I have just seen a sigma AF 28-300mm lens for £100. any thoughts? I know that's a big zoom but thought for a walkabout lens it would be great (not too fond of changing lenses too much) does anyone know if this lens is any good? thanks.
jacqui
jacqui2
Posted 13/02/2011 - 13:48 Link
Or if anyone can recommend a half decent zoom (more zoom than the 50-200mm) keeping in mind funds are pretty limited (as usual) thanks.
jacqui
SteveEveritt
Posted 13/02/2011 - 14:06 Link
You could buy the Pentax 55-300 DAL it is awesome DAL is the cheaper version as it has a plastic mount and no quick shift and also doesn't come with a hood you can pick a brand new one up for circa £130.
It is a stunning lens and there are hundreds of example photos all over the gallery. You won't regret it.
Edited by SteveEveritt: 13/02/2011 - 14:06
