Mirror lens
Bobbinalorry
Posted 29/05/2009 - 21:11 Link
Hi you good people, can anyone out there please help?
I have aquired a 500mm mirror lens; When I try to use it on my K20d
get an 'F' come up on the top screen and I canot access any adjustments. Please help if you can, Thank you.
Best Regards, Larry.
All the gear & no idea.
Anvh
Posted 29/05/2009 - 21:45 Link
I don't have such a lens but so far as I know the lens doesn't have a diaphragm so you can't adjust the aperute (f-number).
You need to set in the menu to enable use of aperture ring, it's somewhere in the custom menu and you should be able to make photos.
edit:typo
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 29/05/2009 - 23:18
golfdiesel
Posted 29/05/2009 - 21:46 Link
You can only use this lens in full manual mode.
Set the dial to M and set the aperture setting to the aperture that the mirror lens has (mostly they are f.
Then you select the shutterspeed that you want for the correct exposure.
It helps if you could post the specs of the lens (make, model, focal length, f-number, etc)
Tamron Lenses: 28-200
Takumar Lenses: SMC 55 1.8
Anvh
Posted 29/05/2009 - 21:50 Link
Remco are you sure about that?
If I use an older lens without auto-aperture I can't set the aperture in my camera.
You need to press the green button and then it meters the lens, you can use M and AV-mode.
Stefan
K10D, K5
AF-540FGZ
Posted 29/05/2009 - 21:52 Link
You can use M or Av modes and in fact if you set any other auto mode such as Tv you will get Av anyway.
Activate the custom function Using Aperture Ring by setting it to Permitted, as already mentioned.
Mannesty
Posted 29/05/2009 - 23:04 Link
It's a rare mirror lens if it's got an aperture ring. They are usually fixed at f8.
Posted 29/05/2009 - 23:39 Link
I think there is one, but I understand that regardless of that even a standard mirror lens of fixed aperture will need the custom function to be activated.
I presume this is because there is no contact electronically with the camera so it doesn't know a lens is attached.
polchraine
Posted 29/05/2009 - 23:44 Link
Not neccessarily fixed at f8. The 400-600 was f8/f12 and I remember trying a non-Pentax lens which did have "aperture" control. Not too sure if it really did change teh aperture or switched in a ND filter. The 400-600 was supplied with several small coloured and ND flters which I have used occasionally.
Posted 29/05/2009 - 23:50 Link
Is the f8/f12 just a consequence of zooming? That is, there isn't any way you can change the aperture yourself, it just changes as you zoom?
polchraine
Posted 29/05/2009 - 23:58 Link
Just a consequence of zooming. The only user adjustment is by adding the ND filters.
edumad
Posted 30/05/2009 - 09:53 Link
I found that the Tamron 500mm severely overexposes on my K10D. I have to increase the shutter speed.
Posted 30/05/2009 - 10:02 Link
I found that as well when I tried one out.
Bobbinalorry
Posted 03/06/2009 - 13:20 Link
Thank you all so much for taking the trouble to help.
The make of lens is 'SIRIUS'
Numbers on the lens are,,,
1:4. 1:5. 1:6. MACRO. 12,15,20,30,70. 4,5,7,10,20 &Infinity.
There is no aperture ring.
Mike-P
Posted 03/06/2009 - 13:48 Link
All my Tamron Adaptall 2 lenses overexpose, I have to dial in -1 compensation whenever I use them with my PK/A adapters.
Mannesty
Posted 03/06/2009 - 16:28 Link
I think those numbers are from the focus scale and will give an approximation of the distance between camera and subject in feet and meters, or the magnification factor (EG:1:4). if the lens has no aperture ring it'll be fixed at (probably) f8.
Edited by Mannesty: 03/06/2009 - 16:30
