Angle of view for Pentax M lenses
but it does help
This is a good site (but a weird one!) and it may explain why I'm have got confused info before - WHY would anyone need to know what the diagonal AOV was?
Reason for the question is, of course, that I use film and a 1.5 crop, plus some other lenses, and it's easier to recce with a protractor and a note book and come back when the light might be good, with the right lenses....
but it does help
to determine the focal length of any lens
Hope that helps!
My Photobucket
28mm f3.5 - 75
50mm f1.7 - 47
135mm f3.5 - 18
I realise now (belatedly, and thanks to the responses/docs in this thread) that some (all?) manufacturers - including Pentax and Sigma - use the DIAGONAL for the angle of view spec.
This probably makes sense for Medium Format as the size/shape of the image size can change (6x7, 645, etc etc - also makes sense if you went to art school and take funky slanted horizons, or prefer headless horse pictures
Anyways, I now have the means to update my measurements for 35mm and APS-C - just need to rework my Px67, because I reckon the ones I have are diags too ('square on the hypotenuse' rings a bell; I'll look it u on Wiki).
So if you notice someone wandering about between 10 and 2 with a protactor (possibly wearing shiney shoes) I'll be back at some point with the right lens and wearing boots
This does back up the theory that buildings do not get bigger (or move) between the recce and the final tripod set up
I guess it the logic of the people who make the lenses v the logic of using them - just quirky enough to confuse you.
Thanks John!
For 35mm frame: Diagonal = 43mm, height = 24mm, width = 36mm
Given the angle for diagonal = 84 degrees (24mm lens)
Angle for width = 36/43 x 84 = 70 degrees.
Angle for height = 24/43 x 84 = 47 degrees.
For the other lenses substitute the lenses' diagonal angle in the formula above.
jas
BigTed
Member
London
Does anyone have angle of view for SMC M:
24mm f2.8
28mm f3.5
50mm f1.7
135mm f3.5
.. before I get the matchsticks, the blue tack and the protractor out?
Thanks!
