Metz 40MZ-2
The only thing to watch with some very old guns, is if the trigger voltage is extremely high. Current wisdom seems to be that if it's under 10V you're definitely safe, and most guns are unless they're very old indeed. Best to measure it to be sure.
K10 (brilliant Digital)
MZ-S (brilliant film camera, still use it for B&W)
Thanks ChrisA......I'll have a look, but I'm sure it only takes 4 AA's so cant be that powerful....
You are correct - you cannot use the TTL mode.
However, I have excellent results with the 50MZ5 + SCA3702 and K10D
Just:
* Flash in "A" mode
* Camera Av mode
* Do NOT use Auto ISO, but fix the ISO (preferably with the front wheel - see custom settings)
On my Metz the flashgun tracks the ISO and Aperture selected on the camera and produces a great result. To get an ambient/flash balance:
* Set the K10D flash mode to Rear-Curtain Sync mode (press Fn button)
* Dial in -1 to -2 stop of underexposure on the camera
Now ambient will be 1 to 2 stops down and the flash will fill in the rest. Gave me great results
I've started writing a "Pentax Flash Guide"...
Chris - the Pentax DSLRs are safe to at least 300V. It's only Canons that blow up (Nikons are protected too - at least on the D300).
I've heard that too, but that's a scary voltage.
It bl**dy hurt, too, when I was a little bit careless with the probes when I was measuring it..
The 40-2 can be both, as it can be made as a Hotshoe and has a hammerhead addapter...
Would love a Pentax/Metz hybred.... lol
Its just a shame Pentax does not make a Hammer head flashgun
It's also possible to make a good hammerhead flash. You need a hotshoe grip + bracket, either an AF500FTZ or AF540FGZ, hotshoe adapter F and 5P extension cord F. The hotshoe grip needs a modification, you need to drill a hole to isolate the extra pin on the flash. Matt has documented the mod here.
Not worth selling mine
Mind you... it weighs half a ton Might put up some shots taken in "A" mode later.
you now have a dangerous stun/taser gun.
[quote:3496ace15f="MattMatic"]Chris - the Pentax DSLRs are safe to at least 300V.
you now have a dangerous stun/taser gun.[/quote]Not half as dangerous as when you're holding the voltmeter probes one in each hand.
Carisbrooke
I've got a Metz40MZ-2 flashgun I used to use with my Pentax MZs film camera.
Lovely camera, great flashgun...
Now....I'm all Digital...my K10D is a great camera, but the flashgun is not PTTL.....
Is there anyway I can use it with my digital kit,...or is it just not compatable
Thanks for any help.
D
