Manual/Autofocus Switch jamming on ist DS
Posted 16/11/2005 - 13:43 Link
I have had an ist DS for about six months - after a few months of use having set the camera to focus manually, the a/m focus switch jammed on the body (to manual) yet the lens was focussing automatically. The body went back to Pentax and they replaced it - a brand new body. Great - but after a week of use, exactly the same problem has happened again - my Sigma 170-500 having being focussed manually has caused the switch to jam again!!! Seems like a problem with what I'm doing or the lens - but how can a lens cause a mechanical fault on the body - any help??
Don
Posted 16/11/2005 - 20:32 Link
If the switch on that lens is a mechanical link, from the body to the af motor, then a problem with the lensmount could be the culprit...ie mounting a heavy lens to the tripod mounted body could've damaged the lensmount ever so slightly, causing binding on the gears in the lens, increasing the load on the camera body. Equivellent to turning the manual focus ring with body switched to af.
Don
Posted 16/11/2005 - 20:33 Link
first line error meant to say if the switch on that camera body is a mechanical.....etc
Posted 18/11/2005 - 07:32 Link
Thanks Don, but I don't think this is the case - the lens is still autofocussing fine, but because the switch has stuck it won't manually focus (same happened before). I forgot to mention (perhaps critically) that this seems to happen when I have used a teleconverter.
