Maidenhead
Posted 25/06/2018 - 22:28
Beautiful Memories captured there and all the better for them taken in full sunlight.
Just goes to show, if there is one medium that doesn't need rules it's photography!
C.O.L.B.A.S victim
Posted 25/06/2018 - 22:32
Well captured.. Lovely work..
Stuart..
Stuart..
Posted 25/06/2018 - 23:42
Really nice shots those...showing the MX-1 as a very capable little camera.
Karlo
Karlo
Posted 26/06/2018 - 00:19
These certainly make the most of the lighting, which is quite hard to work in when its fairly harsh. I especially like the lamp shadow and the path under the bridge, both giving little titbits of what it would be like to be there. The wider views all convey a sense of relaxation and a sort of 'basking in the sun' feel.
The contrast is well controlled, I'm curious because I'd have expected darker shadows and higher contrast ..... did you have any shadow lifting set in the camera, or applied when processing? In any case its worked and has given a lighter feel to the photos.
Posted 26/06/2018 - 18:06
Thank you for your comments to D-F, Stuart, Karlo and Nigel.
Nigel, to answer your query, the MX-1 does have some simple options for D-range Settings - I had them set at Highlight Correction = Auto and Shadow Correction = On. I also applied some selective fill light in PaintShop Pro to bring out a bit more from some of the darker areas. I suppose the remarkable thing is that the MX-1 does capture usable shadow details from its small sensor quite effectively.
Cheers.
Philip
Cheers.
Philip
Posted 27/06/2018 - 08:35
Really nice shots of a really nice area.
Just goes to show that we don't always need the biggest and best gear.
Great set
Great set
Posted 28/06/2018 - 09:26
Thank you, Derek.
Cheers.
Philip
Cheers.
Philip
Herts,
England
1. The A4 road bridge taken from the Rowing Club landing stage:
[IMG]http://i67.tinypic.com/m7ygzn.jpg[/IMG]
2. The Thames path under the bridge:
[IMG]http://i66.tinypic.com/11sdssx.jpg[/IMG]
3. An old boathouse next to the bridge:
[IMG]http://i68.tinypic.com/svru36.jpg[/IMG]
4. The new development next to the boathouse:
[IMG]http://i64.tinypic.com/259y0xt.jpg[/IMG]
5. A fountain by the Thames:
[IMG]http://i65.tinypic.com/nltufo.jpg[/IMG]
6. The bridge from the other riverbank:
[IMG]http://i67.tinypic.com/15gpac6.jpg[/IMG]
7. The shadow of a bridge lamp:
[IMG]http://i66.tinypic.com/11lk6du.jpg[/IMG]
8. Part of the Brunel rail bridge visible from the road bridge:
[IMG]http://i68.tinypic.com/24v8tpu.jpg[/IMG]
[ JPEGs from the MX-1 with a few tweaks in PaintShop Pro; mono using Nik Silver Efex.]
Philip
