Magnolia Blossoms
Posted 03/04/2009 - 22:56
Robin,
It's generally better to post one picture at a time if you want comments.
In my experience, the best flower pictures tend to throw the background out of focus - usually through the use of a wide aperture. Your middle picture (I didn't check the others) was taken at f9.5. My choice would have been F2.8 or f4, which would have virtually extinguished the rather distracting twigs in the background.
Furthermore, it is very difficult to take a satisfactory picture of a flower which is predominately white. The dynamic range usually exceeds the capacity of the film or sensor. Here, most of your petals are blown out.
The last picture has a better (more out-of focus) background, but I think it is marred by two things. First, the angle, looking up, means we don't get to see inside the flowers; and second, it isn't as sharp as it might be. Compositionally, however, it is the best - because the flowers are nicely isolated, unlike the first two pictures, which are rather busy.
Posted 03/04/2009 - 23:10
I think your photos are basically OK, I find the biggest problem is DOF and light and for real close up you need a tripod, you will learn with lots of practice, I take 100's of photos of flowers and bin most of them you can see some of mine on my portfolio I hope it helps you.
Jack.
Jack.
Posted 04/04/2009 - 00:12
But then, going for wider aperture would cause the flowers being out of focus (#2)? So maybe rather 5.6 than 2.8?
George, about whites blown out - would it help if there is some shadow or the light is not so strong?
Magnolies are beautiful blossoming
Kind regards,
Michal R. Hoffmann
Michal R. Hoffmann
Posted 04/04/2009 - 09:16
Robin, just looking at these makes me feel good. You have to accept that there are those who want the photos to be perfect, technically. I just love nature and the way creation gives us such perfection. Catching that perfection is a long road. Don't be disheartened and do take on board what is being given to you, and eventually, yes, eventually you will please even the purist with your efforts. I like them, you like them, that is a start. regards Ronald.
Posted 04/04/2009 - 10:26
I don't that matters too much as long as a critical part of the flower is in sharp focus, but I would agree that if f5.6 is sufficient to blur the background adequately then it would be fine. Incidentally, there is no right answer here.But then, going for wider aperture would cause the flowers being out of focus (#2)? So maybe rather 5.6 than 2.8?
Yes, it would help. My point was that it takes quite a bit of effort to capture satisfactory whites (and blacks), but it can be done. Lowering the contrast is key.George, about whites blown out - would it help if there is some shadow or the light is not so strong?
Indeed.Magnolies are beautiful blossoming
Posted 04/04/2009 - 10:30
Looking at this again, I would be inclined to try a very tight crop on the three flowers in the middle picture, and then, perhaps, try to clone out the unopened flower in the background. I'm not usually a clone-ophile, but it might be merited in this case.
Posted 04/04/2009 - 18:28
Thanks, everyone...I will inwardly digest...currently doing battle changing a mid position valve on my central heating.
Rob
Rob
K20D
MZ 50
Pentax lenses....DA* 55mm f1.4 SDM ....F 35-80 f4-5.6....DA 18-250 f3.5-6.3....F 100-300 f4.5-5.6, D FA Macro 100 WR f2.8.
Centon mirror lens 500mm.
Pentax Flash ....AF 360FGZ
JVC 3ccd GZ MC 500EK camcorder
MZ 50
Posted 04/04/2009 - 23:48
Good luck then. Oh, you should be happy it's not a mid-winter then
Kind regards,
Michal R. Hoffmann
Michal R. Hoffmann
Posted 07/04/2009 - 11:51
Bit of sunlight here in S E Wales, been trying out different WB settings on tripod....what a difference.
BTW, changed valve and cylinder stat, rewired box and sorted leaks....EVERYTHING hurts....she that must be obeyed says I'm getting to old for this DIY stuff.
Rob
Rob
K20D
MZ 50
MZ 50
S E Wales
MZ 50
