Macro Reversing Adapter
The focus will be fixed so you have to move the camera/subject to bring the subject into focus. Also you will have to stop down the aperture manually.
Optically the results from this setup will be pretty good, not quite what you'd get from a true macro lens but probably the best way to try it out on a tiny budget.
but it does help
Also, reversing a 28mm onto a 135mm can give interesting results.
You get even more magnification by reversing a 28mm lens.
PPG entries.
If it goes ok, might have a look on the bay for one of those
Rich
Standby for more questions
Rich
Cambridge
Bit of advice/your opinions if you wouldn't mind please
How effective would one of the reversing adapters be for a spot of macro used in conjunction with my Pentax A 50mm f/1.7 lens?
I realise that its not going to be anything like a true macro lens, but wouldn't mind giving it a try although must say its not really my thang
Cheers and have a good weekend
Rich
