close-uplens filter or macro extension tube
Posted 02/07/2009 - 22:43
So called 'close-up' filters are usually of poor quality. A decent set of extension tubes would be my recommendation. If you can find a set that has all electrical contacts and preserves AF, though it's not really necessary for macro work, then go for those.
With extension tubes you get no loss of image quality like you would with most, but not all, close-up filters.
Posted 03/07/2009 - 01:09
Hi jamal i've just bought some macro tubes from ebay they seem good quality to me.Though they don't have the electrial contacts but they were only £9.99
Posted 03/07/2009 - 08:10
thanks for your comment,Hi jamal i've just bought some macro tubes from ebay they seem good quality to me.Though they don't have the electrial contacts but they were only £9.99
yes ebay where i saw the tube, is that this one you recoment with electrical contacts if not would you mind to send me the link for it please.
link
Posted 03/07/2009 - 08:56
But you have to be careful as some extension tubes have no aperture control which can make focussing very difficult and will give you no control over DOF.
Posted 03/07/2009 - 09:12
Pentax made a couple of good close-up lenses (filters if you like!) and others from major manufacturers like Hoya, B+W, Heliopan, etc. should also be fine.
The humble close up lens can be useful as it is (relatively) cheap, needs no change in exposure, retains all the auto functions and, because we generally stop down to f11 or smaller for closeups, offers very good results.
It can be a good place to start to see if we like that sort of photography and then later maybe move onto a proper macro lens.
Posted 03/07/2009 - 09:18
link
Yeah jamal i bought those.Hong Kong to uk in about 5 days not bad
link
Posted 03/07/2009 - 09:46
A cheap 50mm manual and extension tubes from Hong Kong or whatever will give you a "dedicated" macro for little money.
Hi. My name is Joel and I'm a travelholic.
Stolen kit: Pentax K7 #3428965 and Pentax FA 43mm #0028350
Posted 03/07/2009 - 09:52
thank to everyone for your help.
really appricate your helps, it does help a lot.
i think i ll get a cheep extension tube to start with, than save up for a proper macro lens,
great regards...
great regards...
Posted 03/07/2009 - 12:01
The alternative is to use a 2x converter, which will turn a 50mm f2 lens, for example, into a 100mm f4 macro lens. Not the same quality, but at least you would see if that lens spec met your needs.
The refinement of this is to use a 2x Macro converter, which is specifically designed for the purpose.
Posted 03/07/2009 - 23:08
sory if im being anoying, i dont have any idea about macro lenses,
what about Tamron 70-300mm macro.
how good will this be compering with the other macro lenses?
Posted 03/07/2009 - 23:25
how good will this be comparing with the other macro lenses?
As far as my understanding goes that isn't a true Macro lens.sory if im being anoying, i dont have any idea about macro lenses,
A true macro lens have a magnification of 1:1 or greater, I believe that most zoom "macro" goes to 1:2
Macro lenses are also (mostly?) prime lenses and special designed for macro, the Tamron 70-300mm macro isn't designed specially for macro but to do well as a tele-zoom lens and has the macro as extra feature to say it simple.
With macro the DOF is important and it is also very flat with macro lenses, with most other lenses certainly zooms the DOF can be curved.
Some normal lenses also don't preform well with close focus as with normal focus since they aren't designed for that.
Macro lenses of course will preform well with close focus but might preform not as good with normal focus.
sorry that it isn't written very well, hopefully it's readable
Posted 03/07/2009 - 23:30
thanks anvy its very clear,
and thans ever one for help.
Posted 03/07/2009 - 23:34
Glad it's readable Jamal
Going a bit off topic but when can you put the definition MACRO behind a lens name?
Are there any rules or standards for that?
i want to get some better close up pictures, i don't know which of above would be better option to get,
thanks...
regards
