Macro Flash
Posted 13/02/2008 - 13:50
I am looking for a macro ring flash also and you are right there is nothing on the market which is P-TTL compliant with the Pentax.
So i was just going to get one these cheap E-bay flashes and see how it goes.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=290205430662&ssPageName=STRK:MEWA:IT&ih=019
The idea you have with the 2 flashes side by side sounds a little cumbersome and i think you would end up with too much flash power
Camera:|K-7|
Posted 13/02/2008 - 14:49
I have seen adaptors in the past, such as this one:
http://www.flaghead.co.uk/pages/ringflash-intro.html
I can't vouch for them, all you would need to do is get it to fit your flash gun!
This is what AP said about it: "Cumbersome it may be, but the large ring and the fact that it fits over your existing flash makes this a great buy."
Flash: Metz 58, Metz 48
Posted 13/02/2008 - 15:06
OMG i look like an idiot already when i'm in the bush with my macro, can you imagine what i would look like wandering around with that I have seen adaptors in the past, such as this one:
It looks like a robots arm
Camera:|K-7|
Posted 13/02/2008 - 15:56
Put it this way, if it is the only option that can give you p-TTL, would you really mind?OMG i look like an idiot already when i'm in the bush with my macro, can you imagine what i would look like wandering around with that
Anyway, big camera, big flash - people always assume you are a pro!
Posted 13/02/2008 - 15:59
looks kind neat (maybe not for the bush...)
But covering up the front of the flash that way... Does the sensor on the flash body not get used at all during P-TTL operation?
Just wonderin'
Just wonderin'
MZ-6,K10D,K20D,Grip,DA*Zooms,DA 18-55-200 Kit,FA50,1.7TC,AFZ360
For Saleentax FA28-90,FA100-300,Sigma EX28-80,DC18-200,
Makinon 500mm Mirror
Posted 13/02/2008 - 16:11
Looks like a big gap in the market for a ring flash for Pentax K Models.
Market opening for someone or even Pentax... to fill.
Posted 13/02/2008 - 16:44
Jamie, P-TTL stands for Preflash Through The Lens metering Does the sensor on the flash body not get used at all during P-TTL operation?
The sensor on the flash is used for A mode and remote slave.
I've been trying to find out dimensions of the SB800 and 580EX to see which would fit the AF540 or AF360... might have to measure a friend's 580EX
Posted 13/02/2008 - 17:34
here is a list of the flash heads the adapter fits Quote:
Note: the adapter wont fit the 580ex MK II as it is 2mm wider than the
MK I.
Canon 580EX
Metz 58 Series
Minolta 5600 HS
Konica/Minolta 5600 HS (D)
Sony FLV-56AM
Camera:|K-7|
Posted 14/02/2008 - 11:04
A good alternative to a ring flash, which can produce somewhat harsh lighting, is a camera mounted or handheld wireless/wired flash equipped with a Lumiquest Softbox or Mini-softbox. Best of all, they are cheap to buy.
A while ago I started to make a dual flash system for macro work using 2 x AF240FT flashes. It got very cumbersome and I abandoned the project. Also, it was a TTL or manual only solution, not PTTL and would only work properly with my *istD, not the K10D.
Posted 14/02/2008 - 22:49
I swear by this combination - gives nice, soft, but slightly directional light. I think a ringflash's lack of shadowsmakes the subject look too flat.A good alternative to a ring flash, which can produce somewhat harsh lighting, is a camera mounted or handheld wireless/wired flash equipped with a Lumiquest Softbox or Mini-softbox. Best of all, they are cheap to buy.
I use a manual flash, f/11 @ISO200 gives a correct exposure at 1:1 reproduction with my 105mm lens.
Dan
Posted 14/02/2008 - 23:18
Could you post a pic of your setup please Daniel.
Thanks in advance.
Thanks in advance.
Posted 15/02/2008 - 11:11
Of course!
Here it is on my K10D, Sigma 105mm f/2.8, and Centon flash. I like the Centon because it has a 2 second recycle time, so there's no too much time hanging around between exposures. Also got a tilt and swivel head.
And a couple showing the results. The Shield Bug is cropped very slightly, the Hoverfly was down to about 1/3 of the frame. Note the shadows, nice and soft, but giving a better 3D appearance than a ringflash in my opinion (each to their own of course ).
K10D, 105mm, ISO200, f/9.5, 1/30s.
Dan
Dan
Posted 15/02/2008 - 11:21
...and here was my first diffuser:
https://www.pentaxuser.com/forum/viewtopic.php?t=2531&postdays=0&postord...
The Lumiquest one I use now is this one: http://www.7dayshop.com/catalog/product_info.php?cPath=777_1&products_id=100...
Dan
Dan
Could I use two flash guns in place of a ring flash, i.e side by side and how to make the connections?
Any advice appreciated.
P.S. I am still a beginner.
