M42/K Mount adaptor on K-x?
Posted 12/01/2011 - 10:37
Metal is fine (I haven't seen one yet that isn't metal to be honest). What you need to watch for is that it sits flush within the throat of the camera's bayonet socket - there are some out there that sit over the top and these latter ones won't allow your old lenses to focus to infinity.
Joining the Q
Posted 12/01/2011 - 10:46
Many thanks for your help hefty.
Pete
Pentax K-3, Pentax K-x, DAL 18-55 WR, DAL 18-55, DA 50-200 WR, DAL 50-200, Sigma 70-300mm APO Macro DG, Battery Grip, Metz Mecablitz 48 AF-1, FluCard.
Posted 12/01/2011 - 10:51
You're welcome. If in doubt buy a genuine Pentax one - they're more expensive but they're beautifully machined and always fit perfectly (some third party adapters can be a bit on the tight side, leading to panic when they don't want to be removed). The Pentax ones are made from chrome plated brass so there's no chance of any small metal shavings falling into the innards of your camera either (something to watch for if the adapter is made from something soft like aluminium).
Joining the Q
Posted 12/01/2011 - 11:12
OK, good point. I have seen a genuine Asahi Pentax one for a total of £22.48 delivered - do you think that is a little pricey? The other one I have seen, which may not be a genuine item, is currently only £3.49.
Pete
Posted 12/01/2011 - 11:36
While it may seem pricey, £22.48 is an unusually low price for a genuine one nowadays. Current RRP is around £60. If you're keen on a genuine one I'd snap it up
Personally I've only used the £3 varieties, they seemed okay but I've only ever had 3. There may be some duff ones out there.
PS: The second-hand re-sale price on the genuine ones is often around £25-30...
Tim
Posted 12/01/2011 - 14:21
I went through several of the cheap £3 type versions, none of which were a particularly good fit and all requiring some sort of key/tool to remove. Once I had the genuine adapter (and yes they are comparatively expensive) I could see what the fuss was about.
As Tim says above, £22.48 is a bargain for a genuine adapter whereas I'd say £3 for a third party one is a false economy - buy cheap buy twice...
Joining the Q
Posted 12/01/2011 - 16:01
Thanks both - I now have my eye on a genuine one for £8 (yes, not a typo!) - I'll let you know if I get it (hopefully Friday).
Pete
Posted 12/01/2011 - 16:11
I wouldn't risk my camera on a third party version. But the genuines are unfairly priced new IMO.
Posted 12/01/2011 - 16:12
Well if you're going to get the £8 one how about PMing me the location of the £22 one so I can see what all the fuss is about?
Tim
Posted 13/01/2011 - 08:12
thoughton wrote:
Sorry thoughton, only just saw this. Hopefully you'll get this in time, as there are only 11 hours left:handlep wrote:
Well if you're going to get the £8 one how about PMing me the location of the £22 one so I can see what all the fuss is about? Thanks both - I now have my eye on a genuine one for £8 (yes, not a typo!) - I'll let you know if I get it (hopefully Friday).
link
Pete
Posted 19/02/2011 - 18:18 - Helpful Comment
Comments on a couple of non-Pentax brand M42 adapters.
My wife and I used to use Spotmatics a lot. When we decided to go properly digital we chose the Pentax K-x in the hope that we could use our old Takumar 42mm screw-in lenses for odd occasions.
I am well aware of the strong recommendations on this, and other forums, to buy only the genuine Asahi Pentax M42-to-PK adapter (the topic comes up frequently: try a search for adapter/adaptor + m42). However, being a tightfisted pensioner I hesitated about paying out over 60 pounds for a new genuine Pentax adapter, or even 25-30 pounds for second hand ones on eBay. We are only likely to want to use the old lenses very occasionally.
I have now bought, cheap on eBay, two branded "infinity-focus" (ie: flangless, flush-mounting) adapters. Here are some comments on them that others may find helpful.
KOOD "Made in Japan" PENTAX/M42 ADAPTER. These come up from time to time on UK eBay and I got one for under 5 pounds (plus postage) in very good condition, boxed, with the dismounting key. It is made from some light alloy and painted black. The paint seems well applied, but nevertheless there might be a risk of tiny flakes coming off and going into the camera. The locking spring, on the one I bought, looked distorted as though a previous owner had struggled to get it off the camera - this is the commonest complaint about non-AsahiPentax adapters. I would not even try risking it. I got a friendly local watchmaker to remove it - the spring is fixed to the adapter by the tiniest X-head screw I have ever seen, and it was in pretty tight.
With the locking spring removed, this adapter goes on and off the K-x easily, and when fully clockwise it is quite snug and I see little danger of the lens+adapter accidentally falling off.
The KOOD adapter has a small inward flange at the inner (mirror+sensor) end of the 42mm screw thread. The flange reduces the inner diameter at that point to 37.3 mm and it fouls the diaphragm actuating pin on the base of a Takumar lens, so one cannot quickly go from full aperture to a smaller aperture just by moving the Auto/Manual slider. One is effectively always on Manual from max aperture down to (or nearly down to) the smallest stop. On our Super Takumar 50mm lenses one has to click all the way down from f 1.4 to the desired stop. Only when going right down to f 16 does one have to engage "Manual", as the flange does not push the pin in all the way. Of course, while doing all this one risks disturbing the focus or framing slightly. If you could tolerate this, then the Kood, with locking spring removed, is a cheap adapter for occasional use.
Warning: one of our Spotmatic lenses is a late S.M.C. Takumar 28 mm. This lens has a tiny spring-loaded pin on the baseplate, just clear of the 42 mm screw thread. As far as I can see its sole purpose is to lock the AUTO/MANUAL slide lever when the lens is off-camera, to prevent accidentally changing the mode. The rectangular cutouts, for the dismounting key, on the forward face of the Kood adapter, clash with this tiny pin. One has to depress the pin (eg with a fine screwdriver or penknife blade) in order to fully tighten the adapter onto the lens. More importantly, it also fouls the cutouts when starting to unscrew the adapter from this lens, and one must be able to depress it before one can separate lens and adapter. If one is also using the adapter with the locking spring still in place, you are in a Catch 22 situation: you can't get the lens+adapter off the camera because you can't get at the locking spring to free it, and you can't get the lens off the camera+adapter because you can't get at the tiny pin to depress it clear of the adapter. Perhaps an engineer's thin feeler gauge would just do the trick if you could slip it in before the pin springs up into the cutout slot? I wouldn't risk it!
JESSOP BODY MOUNT ADAPTER. M42 Pentax-K. I bought one of these on UK eBay for just over 8 pounds (plus postage) in near-new condition. It seems better made than the KOOD adapter - chrome plated brass, I think. As the locking spring was in perfect condition I tried mounting it on our K-x body. It went on easily, but getting it off was a little stressful. It is said that the genuine Asahi Pentax M42 adapters do not need the demounting key to remove them: the spring can apparently be depressed with a fingernail. I found that I had to use a small screwdriver blade to fully depress the JESSOP locking spring, while easing it all back and forth with the demounting tool. Once bitten twice shy. I promptly removed the spring - it is held with a small slot-head screw.
Without the locking spring, the JESSOP adapter is a snug fit and I think there is little risk of a lens falling off accidentally. The tiny pin of the S.M.C. 28 mm (mentioned above) does not foul the dismounting slots in the way that it does with the KOOD. The adapter does not interfere with the diaphragm pin, so one can use a Takumar as a manual preset lens: chose the working aperture with the lever on "Manual". Focus at full aperture with the lever on "Auto" and then just move to "Manual" for the exposure.
With any of these flush-fitting adapters the Takumar 42 mm lenses have to be treated as dumb manual lenses. I would be happy to use the JESSOP brand adapter (sans-spring) with any of them, but I will keep the KOOD in reserve and probably never use it.
By contrast, we also have a good Tamron 90 mm macro lens, with some Adaptall mounts. I have recently bought a very simple Tamron Adaptall II "Pentax KM" mount, and the combination works well. Manual focus, of course, but the lens stops down from full aperture to whatever f-stop one selects during exposure and then snaps back to full aperture. No Auto/Manual lever on this, unfortunately, to check DoF. AE seems to work well on the Av setting. On Manual exposure mode I just check each histogram and adjust as necessary, when taking macro photos of stationary objects.
Posted 19/02/2011 - 23:19
Many thanks for the detailed review, which I'm sure will be found helpful.
Posted 20/02/2011 - 08:03
Hi,I have been using the M42 mount on my Pentax ist dl with a Takumar f1.8 55mm lens, for food Photography.
Results (Outstanding).
Go to my images on the Gallery.
Deon.
Deon.
Any advice appreciated, thanks.
