m42 adaptor and k20d
abesad
Posted 12/02/2009 - 17:18 Link
When you fit a pentax (genuine) adapter to k20d, do you need to alter anything in the menu, or can you just put it on with the lens and away you go?
Thanks for taking the time to answer this for me.
susan
Malo1961
Posted 12/02/2009 - 17:50 Link
Hi Susan,
It's very easy:
1# Put the adapter on by aligning the red dots and turn clockwise until it clicks.
2# Set: "Permit use aperture ring" to On in menu.
3# Now the fun part. You have two options for metering.
Set camera to manual metering (M), turn aperture ring to desired value and use green button for metering. By pushing the green button it will automaticly close down and meter.
Or:
Set camera to AV. meter wide open to focus, then close down aperture to desired value ( you see the shutter speed will change, by doing that.
Then take your picture.
Note: Make sure the manual/auto switch on your lens is turned to Manual.
The word manual must be visible. This allows you to manually close down the aperture.
Tip: You have a big chance your metering will be inconsistent. This has to do with the OEM focusing screen. Only the K series dslr's from pentax suffer from this glitch. Prepare for underexposure from wide open until F4 or F 5,6. Above those apertures it can suffer from over exposure of more than 2 stops. The best way to cure that, is by putting the OEM screen from the *IST D/DS in your K20D.
I did it, and my K10D has a much more reliable metering now. I only have to dial in + 0,7 ev compensation and the metering is spot on, with all the used apertures.
Have fun with all those beautiful Takumars.
Martin.
Best regards,
Martin.
iceblinker
Posted 12/02/2009 - 19:07 Link
I don't see why there would be any special exposure error when using Av mode with the lens stopped down.
Bad errors happen when using M mode with M and K lenses, but this question is about M42 lenses.
~Pete
Malo1961
Posted 12/02/2009 - 19:31 Link
Sorry Pete
There simply is. I use Takumars a lot and my k10D had all the problems I mentioned above. Yes....the same with K and M lenses.
But it is a well known issue amongst KxxxxD users who use Takumars.
And there is a lot written about it, and possible cures to prevent the exposure errors. Examples are found here and also here IF you google : K10D Exposure problems M42 lenses
You get of lot of info about that subject.
HIH,
Martin.
Best regards,
Martin.
iceblinker
Posted 12/02/2009 - 20:39 Link
I don't understand where the error is coming from if using Av mode with the lens stopped down.
~Pete
Malo1961
Posted 12/02/2009 - 20:56 Link
It has, (as I understand)with the non linear focus screen Pentax started to use for the k10D and other kxxxxD's afterwards.
And it has nothing to do with AV mode. In manual using the green button, the same happens.
There is a lot written and discussed about it. Typical is the fact that the best cameras (metering wise are the *IST D's.) That's why the best way to fight this problem is placing the *IST D OEM screen (LL-60 -AF Mat)
in the k10D/K20D.
The other side of the story is : By using that trick you have permanent under exposure of 1-2 EV when using your A and DFA lenses.
Best choice for all of this: Get a *IST D/S/L cheap from ebay and permanent use that for takumars or K/M lenses. Or get a second hand K10D, convert the focus screen as mentioned above and use that permanent. Otherwise you keep changing focus screens when you decide to change type of lens. And who wants that? I know I won't.
Martin.
Best regards,
Martin.
iceblinker
Posted 12/02/2009 - 21:38 Link
I have read quite a lot about metering with Pentax digitals and various lenses and modes, and I do some manual photography. I think two things are being mixed up.
One is the serious specific problem of stop-down metering via the Green button not working properly, relevant to M and K lenses. The other is about more vague general concerns about metering which may happen with any type of lens.
Metering tends to be quite reliable with any lens when it is wide open. A lens that can be kept stopped down to the desired aperture is effectively the same thing. For example, shooting at f5.6 with an f2.8 lens that can be held at f5.6 is effectively the same as shooting with an f5.6 lens.
Anyway, even when there are errors, personally I would rather compensate for them than use a dimmer focusing screen.
~Pete
womble
Posted 13/02/2009 - 00:41 Link
What happens if you fit a katzeye screen instead?
iceblinker
Posted 13/02/2009 - 00:56 Link
Same exposure problems with the Katz Eye when stopping down M & K lenses.
~Pete
Malo1961
Posted 13/02/2009 - 06:01 Link
There are no things mixed up here, Pete.
A M42 lens attached to the K10D by the adapter is basicly the same as a K lens.
No electrical contacts to communicate with the camera.
You already agreed on the fact K/M lenses cause exposure problems when using stop down metering with the green button.
Fact 1: You can't use K/M lenses in AV mode. They will stay wide open.
Fact 2: Every lens (K/M or M42 with adapter will meter correct when used wide open.
Fact 3: Only Takumars allow you to use stop down metering in AV mode because of the manual/auto switch present on each takumar lens.
Basicly you are manual imitating the cameras green button mode.
When set to auto it stays wide open, nothing happens.
When set to manual you can stop down by turning the aperture ring.
Of course...this results in darkening the screen, by every stop.
But...In it's behaviour it is still the same as a K/M lens in green mode.
Only now are you closing down the lens, instead of the camera in green mode.
Still no communication because of the lack of contacts on the lens.
Hope it helps,
Martin.
Best regards,
Martin.
iceblinker
Posted 13/02/2009 - 12:35 Link
Yes. My theory is that it doesn't stop the lens down long enough to get a reliable reading, or that the reading is taken before the lens is fully stopped down. A timing error.
You can use Av mode when you want the lens to stay wide open. By the way, Av mode works for other apertures too when selotape is stuck over the place where the electrical contacts would be on an A lens. EV compensation is then needed though.
I was thinking of manual M42 lenses or manual operation.
I know, but this is where I disagree with you. I am suggesting that metering behaves differently when you stop down the lens via the aperture ring than when the camera does via the Green button.
~Pete
Edited by iceblinker: 13/02/2009 - 13:02
Malo1961
Posted 13/02/2009 - 13:18 Link
I was thinking of manual M42 lenses, not auto ones.
Every M42 takumar with M/A switch or even the earlier pre-set types (with the double aperture ring at the front of the lens works manual.
The auto option was added for use of the Pentax ES II.(to allow automatic stop down coupling) Every other brand of M42 lens (be it zeiss, helios ,vc etc is manual, with or with out a switch.
As I said before, the inconsistent metering behaviour is caused by the non linear focusing screen of the Kxxxxxd's.
The *IST D Oem screen is a linear type, that solves that problem.
I still use M/K and M42 lenses on my K10D. With the original OEM screen installed I get inconsistent and unpredictable metering readings.
When I switch the screen for the linear *IST D type, I only have to compensate once by +0,7 ev for the whole aperture range.
And this results in correct exposure, every time with all non A type lenses. And my experience is backed up at 100 + pages or so found
here. A very enjoyable read btw.
best regards,
Martin.
Best regards,
Martin.
iceblinker
Posted 13/02/2009 - 13:47 Link
I still believe there is a difference between metering with the Green button and metering with the lens manually stopped down. Recently for instance, I found metering was OK with an M lens when using manual extension tubes.
And other posters to this forum and DPR have reported that metering is OK with M42 lenses whereas it wasn't with M & K lenses with the same camera and screen.
In what way are new Pentax and Katz Eye focusing screens non linear? What does that mean exactly?
~Pete
Edited by iceblinker: 13/02/2009 - 13:51
hefty1
Posted 13/02/2009 - 15:28 Link
I'm not sure about the "non-linear" part but I was led to believe that the problem with the later Pentax screens is that they've had a bright coating (optional on Katz-Eyes) to make them more bearable when using slower consumer zooms. Unfortunately, when confronted with a genuinely bright lens (say f2.8 or faster) the camera assumes it's looking through an f/4-5.6 aperture and makes its calculations accordingly.
The older DSLR's didn't have the bright coating, hence putting one of the earlier screens in a K10D etc restores the natural balance. If you've bought a Katz Eye screen and specified the bright coating to be applied you'll get the same problem, hence the best bet would be an uncoated Katz Eye screen for MF with older (faster) primes.
Joining the Q
abesad
Posted 13/02/2009 - 15:58 Link
Thank you all, I am trying to get my head around all these remarks you have made. At the moment I struggling with the input focal length, I get No's from 8 to 800. Also I press the green button and it makes a noise,but can't see what it actually does except the shutterspeed seem to move back. for instance if I put it as 1/125 when I press the green button it goes to 1.5". I am using a lens which is fixed to 5.6 as the aperture is broken, it is a 200ft zoom, that what it got on the zoom anyway.Its also got a switch which says A or M and also got a adapter to x2 this zoom.
regards susan
