M 28mm woes
Posted 15/03/2011 - 08:22
I had one M lens which needed repair and the only way the technician could remove the front ring was to drill two small holes in it for a wrench and then fill them with black resin.
Posted 15/03/2011 - 09:54
Try warming the outside of lens with a hair.dryer to make it expand slightly and then try to remove it
Posted 15/03/2011 - 19:44
Thanks for the suggestions guys- will try the hair dryer first and if all else fails - the drill
Many thanks
Carl
Many thanks
Carl
Posted 15/03/2011 - 21:05
Didn't some4one do a lens rebuild here not so long ago and used double sided sticky pads to stick the ring to a flat surface then unscrew the lens off it?
Posted 16/03/2011 - 13:23
How about swapping the rear groups? I've taken my M28/2.8 apart to clean the diaphragm and it should be quite straightforward to change the rear group. From memory, I think you need to do something along the lines of the following:
- Remove the five screws from the flange on the mount.
- Lift mount off
- Use lens spanner to remove the rear group
- Replace rear group with non-fungus infected group from the donor lens
- Replace mount etc.
Best of luck
- Lift mount off
Best of luck
Knaresborough,
North Yorks
So - either remove the rear element and clean the fungus - or swop the front elements from one to the other - either would produce one perfect lens.
Problem - doing either of the above. I have dismantled and re-built many M 50s - I have all the right tools - lens spanners - friction wrenches etc.
I just can not get either the front or rear element to move on either of these. So either the design is substantially different to the M 50 and I am doing something wrong - or they are well and truly stuck.
Any ideas other than the obvious 'leave them alone if they are working fine'?
Carl
