Looking for a cheap manual flash
Posted 26/01/2014 - 22:29
Yongnuo is your friend. Good quality manual flash guns (YN-560 ii or iii) based on a venerable Canon design and superb value for money at around £50-£60. I reckon the build quality of mine is better than the mid-range Metz I used to have. Only issue is the macro thing - would a ring flash be better ideally?
No idea how good they are but you can buy led ring flashes on eBay pretty cheaply.
Posted 27/01/2014 - 07:03
If your looking for a ring flash that works mighty fine with the K30 then look no further than the Viltrox JY-670 which can be had for around £70 on eBay. It does not matter which one you go for (Nikon or Canon) as the hot shoe is a one pin affair.
Here's a short ring flash review page..
http://www.digitalcameraworld.com/2013/04/18/best-macro-flash-6-top-models-tested-and-rated/6/
And here's a thread from the other forum, "note" this flash has problems with the K5II bodies, work fine with the K30 and K3 though ...........
http://www.pentaxforums.com/forums/125-flashes-lighting-studio/188226-viltrox-jy-670-ring-flash-2.html
LED ring flashes are hopeless for moving objects and that includes snails
Brian.
Brian.
13 years
