Locust
polchraine
Posted 08/02/2010 - 08:34 Link
A couple of cropped JPGs ... zoom in and the detail is amazing. Both taken using a DA*16-50 the first at 16mm and the second at 34mm. The second had a shutter speed of 1/6 second hand held which suggests either I have a very steady hand, SR works well or both! The PEFs and BMPs are even better for fine detail.
[IMG]http://i2.photobucket.com/albums/y31/Polchraine/PentaxForum/Locust_crop1.jpg[/IMG]
[IMG]http://i2.photobucket.com/albums/y31/Polchraine/PentaxForum/Locust_crop2.jpg[/IMG]
Just realised that the images have been resized for display here - but they are still at the original size on Photobucket.
Edited by polchraine: 08/02/2010 - 08:39
davidtrout
Posted 08/02/2010 - 09:20 Link
Surprisingly the first picture, taken at the shorter focal length, is less sharp than the second which was taken at 34mm. I would have expected the result to be the other way round. There's no doubt that the DA*16-50mm lens and the shake reduction system work very well but you've also got a steady hand to get the pictures this sharp. However for this type of photography you do need to use a tripod to get top quality results which is why I never attempt pictures like this.
david
polchraine
Posted 08/02/2010 - 09:36 Link
In both cases there was a need to be "quick" - for the first I was balanced on one foot, holding on with my left hand and camera in the right so could not zoom in and wanted to get the largest image possible and I may have been a little closer than the minimum focussing distance.
Tripods are fine if you have time to get set up - but for these, in 2 seconds he was gone.
