Lighting for Macro...
DaveHolmes
Posted 06/03/2013 - 20:30 Link
Just wondered how some of you light up your macro shots...
I've tried off-camera flash and onboard flash using a DIY tubelike director thing (kitchen roll tube lined with foil...)
Both with mixed results (and no keepers as yet...) Seems I do best with natural light...
So, how do you light up your macros?
Digital:
Flash:
Film:
SteveEveritt
Posted 06/03/2013 - 20:32 Link
Diffused ringflash works for me
dougf8
Posted 06/03/2013 - 20:36 Link
The pringles tube with on-board.
Or a diffuse light tent with radio trigger flash top (EF500DG SUPER, left and right AF200T optical triggers.
Lurking is shirking.!
Edited by dougf8: 06/03/2013 - 20:37
DaveHolmes
Posted 06/03/2013 - 20:38 Link
Do you use the lid as a diffuser?
Digital:
Flash:
Film:
dougf8
Posted 06/03/2013 - 20:40 Link
Its a rough and ready one with a rubber band and either tracing paper or a hanky.
I've angled the output so it is more down than forward thus the lid doesn't fit. A bit like this one http://www.pentaxforums.com/forums/pentax-flashes-lighting-technique/146183-diy-...
Edited by dougf8: 06/03/2013 - 20:43
DaveHolmes
Posted 06/03/2013 - 20:41 Link
How do you diffuse ring flash without covering the lens? (this is possibly a stupid question isn't it?)
Digital:
Flash:
Film:
DaveHolmes
Posted 06/03/2013 - 20:42 Link
I'm with you... Going to try this soon!!
Digital:
Flash:
Film:
matwhittington
Posted 06/03/2013 - 20:44 Link
I normally have a 540 flash with an omni bounce diffuser on it, normally wound down to -1 or more, on a cheapo remote TTL cord from the hotshoe. I can then hold it alongside the lens, either side, above or below it, or have it in the hotshoe, or pretty much anywhere else...
Mat W
My Flickr: link
dougf8
Edited by dougf8: 06/03/2013 - 20:46
davidstorm
Posted 06/03/2013 - 20:45 Link
A home-made double-header flash diffuser, tubes with adjustable arms, made from empty Pringles Tubes and fitted over the end of a cheap (but powerful) manual flashgun. Cost £24 (including the flashgun) and produces bright, evenly lit shots with no shadows at F16 and ISO200, like this one which was shot with the Sigma 105 DG EX Macro, 2x Teleconverter and the above-mentioned flash setup.
cbrog
Posted 06/03/2013 - 21:04 Link
Why would you want to - ringflash units are often (usually?) designed to be used for macro work and are low powered with a very short effective range. I use the Vivitar Macroflash 5000 - two of which I picked up on eBay for less than £30 each.
See Leaf Cutter Bee in my portfolio.
Roger.
Edited by cbrog: 06/03/2013 - 21:12
nass
Posted 06/03/2013 - 21:08 Link
This works for me, although I use a different connector nowadays as PC-sync is a binary signal whereas PTTL requires a different signal. One thing to look at is the differential between the bottom of the eye and the top of the eye. It's a problem I havn't properly solved myself yet although I have a slightly different setup this year using a beauty dish. We'll see
Equipment For Reverse Lens Extreme Macro Photography by Johan J.Ingles-Le Nobel, on Flickr
Edited by nass: 06/03/2013 - 21:10
nass
Posted 06/03/2013 - 21:14 Link
This is the sort of eveness you can get with a shape like this, although again this is a slightly different variant which actually stretches diffuser material quite far back too. Because of it being far back it means you can get a bit underneath the subject too. With this particular lens I have a huge working distance of about 10cm or so, so there's plenty of room for a diffuser on top
Small Elephant Hawkmoth by Johan J.Ingles-Le Nobel, on Flickr
cbrog
Posted 06/03/2013 - 21:21 Link
Shots like that make me want to give up macro photography
Brilliant.
Roger.
Renster
Posted 06/03/2013 - 21:55 Link
What an amazing shot!
