Light Advice Please
Posted 01/05/2010 - 20:06
I can't really help on suggestions of starter kits for still photography (I work at the megawatt end ), although I might be able to help if you have some general lighting problems/questions.
But if you want to get started for really cheap, how about getting some pop-up Lastolite reflectors and some angle-poise lamps? May sound a bit heath-robinson, but will work fine for a small subject area!
(for my next trick, I will demonstrate how to make gobos for old Patt-23's out of old offset-litho plates...)
Posted 01/05/2010 - 20:09
I would go the extra few bucks for the Interfit EX 200. It is a distict step upwards and not that more expensive.
The kit works very well and I use one for the occasional times I use studio flash.
Posted 01/05/2010 - 20:22
Thanks John I will take a look at the Interfit EX 200.
Have seen some great DIY lighting ideas at
http://strobist.blogspot.com/2006/07/how-to-diy-10-macro-photo-studio.html
i just want to try my hand at lighting and when i am stuck indoors, so any suggestions will be appreciated.
Angle-poise lamps ???? i will google them as I have no idea what they are so thanks again.
Fletcher8
Fletcher8
Fletcher8.
Posted 01/05/2010 - 23:56
You should look there: http://www.studio-flash.com/
Posted 02/05/2010 - 08:26
Perhaps it might be worth tracking down second hand gear as i am sure there is plenty of quality equipment around at a good price to start you off.
Regards - Pete
Regards - Pete
Posted 02/05/2010 - 09:36
Thanks for your suggestions the http://www.studio-flash.com/ link is interesting so thanks.
Fletcher8
Fletcher8
Fletcher8.
Posted 16/11/2010 - 17:28
Gareth, if you fancy trying a small bit of studio work, my studio & lights cost me ZERO.
I set up a small table top daylight studio in a spare room.
Check out this forum thread and my responses which also show a photo of my free studio set up..
http://photo.net/canon-fd-camera-forum/00OVKc
cheers Steve.M.
cheers Steve.M.
Many Thanks
Fletcher8
