Lens Test Charts
Posted 26/08/2010 - 12:10
Instead of sending him a £10 Note why not just take a
picture of the £10 Note as your lens test
Then buy you and me a drink with the £10 Note
Then apart from him were all better off
Posted 26/08/2010 - 12:28
I sat here trying to convince myself they were of some use, but could not convince myself!Instead of sending him a £10 Note why not just take a
Your idea of a £10 note sounds a better choice.
Regards, Tom
K-1ii,K-3iii's.
SMC PENTAX-F 1:2.8 28mm, HD Pentax-D FA* 1:1.4 50mm SDM AW,
SMC PENTAX-D FA MACRO 1:2.8 100mm WR,
SMC PENTAX-DA* 1:4 300mm ED [IF] SDM,
SMC PENTAX-FA* 1:4 600mm IF & ED,
HD PENTAX -DA 1.4x AW AF REAR CONVERTER,
Pentax Photo Gallery
K-1ii,K-3iii's.
Posted 26/08/2010 - 12:36
There are some available for free download, I've got a copy, but you'll need to get it printed on a pretty good printer at A3 size for it to be useful as a test chart. (At A4 even a 300dpi printer will merge the finest converging lines). I'll see if I can dig up a link, from memory it was some university site.
Tim
Posted 26/08/2010 - 13:37
Not sure how much use it is, but there's one free
from AP. Link in this thread.
Posted 26/08/2010 - 14:16
Had a little dig, the one I use is from Cornell University. Here.
Tim
Posted 26/08/2010 - 14:26
The only lens charts I have ever seen in meaningful use (a BBC camera maintenance workshop) was where the chart stand and the camera stand were cast steel and both bolted to a concrete floor. You will never achieve any meaningful or accurate results any other way, I'm afraid.
Posted 26/08/2010 - 14:30
Except for tomkeet being in prison of course, given that photographing banknotes is illegal Instead of sending him a £10 Note why not just take a
As far as test charts go, the only one I bother with is testing for front/back-focusing, from focustestchart.com
Posted 26/08/2010 - 15:13
I can see where you're coming from Ken, we'll never be able to judge lines per millimeter or any precision measurements like that. What we can do though is tell if a lens is soft at the edges or corners, or find the sharpest aperture.
Tim
Posted 26/08/2010 - 18:21
These wouldn't have been for consumer grade cameras and lenses for which testing in the normal working environment is perfectly satisfactory/desired. Digital has poor resolution anyway so a decent tripod is more than adequate. Flash could be used to minimize any shake. Correct/precise focus is the most important part of any lens test. The only lens charts I have ever seen in meaningful use (a BBC camera maintenance workshop) was where the chart stand and the camera stand were cast steel and both bolted to a concrete floor. You will never achieve any meaningful or accurate results any other way, I'm afraid.
This is a perfectly adequate test for our purposes.
Posted 26/08/2010 - 19:04
Thanks for the information. Think I will just stick to the normal Front/Back focus charts.
Regards, Tom
K-1ii,K-3iii's.
K-1ii,K-3iii's.
Posted 26/08/2010 - 20:20
Don't say that so easy, it's hard to truly compare the two formats since they are different.Digital has poor resolution anyway
Here is a comparison 7 years old with a 135 format DSLR against a Pentax 6X7, according to you the DSLR doesn't stand a chance, here just take a look link
Posted 26/08/2010 - 20:48
Thanks Stefan, I'll read through that tomorrow, but that's not as high as the resolution I'm talking about. Zeiss have managed 400lpmm on film (which is really tiny 0.0025mm). This site gives the maximum digital resolution as 87.5lpmm which means the testing setup doesn't need to be anything more than a decent tripod. Normal film testing used to yield 120-140lpmm again with just a decent tripod.
Posted 26/08/2010 - 21:12
How so? Please give evidence for each of your assertions.
County Durham,
England
Are they of any use compared to the normal Front/Back focus charts?
K-1ii,K-3iii's.
