lens stuck...
Posted 13/12/2005 - 10:27
"I live near Mexico.........."
If necessary, is Tennessee via USPS close enough?
[email protected]">[email protected]
DON'T USE WD40!
There are a great number of knowledgeable folk on this forum. Please give them time to respond before you try forcing anything.
Cheers and good luck
DON'T USE WD40!
Posted 13/12/2005 - 14:38
Without seeing the camera or even a picture of it, it is difficult ot give positive advice. However, whatever you do, do not use WD40!! This is designed to spread and will get in all sorts of places you definately don't want it. Are you sure you are using the right button to release the lens. You can get a copy of the manual here, http://www.pentax-manuals.com/manuals/mf/mfmanuals.htm
Before using it with film, I would try a few basic tests. Open the back and see id the shutter seems to run smoothley at all speeds. Put the camera on B, set the lens wide open, open the back. Press and hold the shutter and look through the lens. Does everything appear clear. If it has been stored in the garage, the damp may have got to it. Is there any fungus? If so, the lens could have started to corrode which is what is locking it. Try a very small amout of oil aaplied with a thin piece of wire around the lens mount and leave it overnight. If the lens now comes off, carefully clean away the traces of oil. If this still fails try to get some digital images of the lens mount area so I can see if I can spot anything.
Kim
Kim
24 years
i live near mexico and there isnt a specialist or even a camera store for that matter for miles.
