Lens mount stiff.......
Posted 03/02/2015 - 17:11
The lens mount is set to a particular tension, so maybe it does need re-adjusting. It's the first time I've heard of one needing it though.
First I would clean mount and lens mount with a soft, lint-free dry cloth. Then check that there isn't something blocking a connector, or that a connector isn't sitting proud of its normal position.
Wiltshire
Is this general grime on the mount and, if so, what's the best cleaner, lens cleaning fluid....?
Or, should one as a matter of "servicing", lubricate the lens mount? With.....?
Thanks for your time,
Roger.
