Lens hood and filter combination - how do I set it up properly?
Posted 10/05/2010 - 13:31 - Helpful Comment
Do not use the two filters together, you are just introducing more reflective surfaces and a possible degradation of image quality.
The sole point of a UV filter is to reduce aerial haze, only seen with telephoto lenses in certain circumstances. I'm afraid that it is a pretty pointless thing to use with your 18-55.
The vignetting you are seeing is due to the combination of filters and hood. It will make no diference how you attach them, they will always protrude the same amount.
Don't you have the original Pentax petal hood? It is designed specifically for use with polarising filters, the little removable portion is to allow access to the rotating filter ring.
Posted 12/05/2010 - 20:32
Can I just chip in that the Pentax hoods sound ideal but they seem so expensive. About £27 each - just for a cylindrical bit of plastic.
Nigel
Pentax K-x, DA18-55 lens, DA50-200 lens, Metz 48 Flash
Posted 12/05/2010 - 22:56
They are the right tool for the job, so if you want the best result the answer is clear. Yes, they seem expensive, but they are efficient.
Posted 13/05/2010 - 08:24
Just another thought about your rubber hood, even without seeing it I'm pretty sure it will be for a standard lens and will cause vignetting on its own at focal lenghts below 30mm.
Totnes
