Lens Fine Tune Adjustment
Fletcher8
Posted 19/07/2011 - 17:53 Link
Have been aware of the lens fine tune function for a while but never really gave it much thought until a few days ago. Anyway after reading an article on the web, I thought I would test my lenses for Front Focus or Back Focus issues. all of my lenses were OK apart from the Pentax 15mm limited which seamed to back focus quite a lot, I have corrected it via the Lens Fine Tune Adjustment. My question is, is back focus common on wide angle lenses?
Fletcher8.
Edited by Fletcher8: 19/07/2011 - 17:54
johnwhit
Posted 19/07/2011 - 18:54 - Helpful Comment Link
I found I needed +5 adjustment on the DA-15 but it was no worse than some of the other lenses, it depends on the flange thickness of the mount on camera and each individual lens as they're all made to a tolerence. As an example I have these settings on the K20D:
SMCP DA 15mm +5
Sigma AF 24mm -8
SMCP FA 28mm +5
SMCP FA 35mm -3
SMCP FA 50mm -4
SMCP DA 70mm -8
Tamron Di 90mm +/-0
SMCP DA*16-50mm -6
John
PPG link
In LBA hiatus.
Smeggypants
Posted 19/07/2011 - 19:10 - Helpful Comment Link
Different settings for different cams here
settings for my K-5s ( last bit of paper I can find )
Sigma 30/1.4, +5, 0
Pentax FA50/1.4, -10, -7
Sigma 17-70/2.8, 0, 0
Pentax DA14/2.8, 0, +2
Pentax DA* 50-135, -3, -3
Sigma 135-400, +5, +9
Pentax DA10-17, 0, 0
Numbers were completely different from my K20D
Sorry about the lack of formatting, forum software removes multiple spaces. I had made nice columns
Edited by Smeggypants: 19/07/2011 - 19:10
Anvh
Posted 19/07/2011 - 19:12 Link
Flang thickness is probably almost the same but it does at up when you consider the little play there is with the sensor, AF module, mirror, viewfinder and every micro meter is one to many.
Stefan
K10D, K5
AF-540FGZ
Fletcher8
Posted 19/07/2011 - 19:57 Link
Thanks info guys!
Fletcher8.
ChrisR
Posted 19/07/2011 - 20:20 Link
Interesting, this is maybe the reason I have never obtained, what I would call, pin sharp focus with digital, the way I did with my spotmatic II, and film.
I have a K10D, can the focus be fine tuned with this camera ?.
Many thanks.
Chris R.
Chris R.
I. El. (Eng). (Rtd).
Anvh
Posted 19/07/2011 - 20:39 Link
Film has some thickness because of the sensitive grains so focus didn't need to be perfect, with digital the part that's sensitive is so flat and small that you see those imperfections.
With the K10D you can do a global adjustment through the "debug menu" but not an adjustment per lens, only the K20D, K7, k5 and the 645D can do that.
I believe you can sent the camera to Pentax with the lenses to have them calibrated though but that will cost you...
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 19/07/2011 - 20:40
JohnX
Posted 19/07/2011 - 22:42 Link
So, for those of you who have calibrated zoom lenses, how?
Did you average across the range, just in the middle, what?
Anvh
Posted 19/07/2011 - 22:49 Link
I used long end because that's the most DOF critical most of the time.
You could do an average off course but i'm actually curious if there will be a difference.
Anyone tested it?
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 19/07/2011 - 22:50
Smeggypants
Posted 19/07/2011 - 23:45 Link
I found a slight difference with my 50-135 IIRC. can't remember exactly how much.
I'm going to re-test ( and if necessary recalibrate ) them all again soon. Should be interesting to see if things drift. I haven't noticed any OOFness though
Smeggypants
Posted 19/07/2011 - 23:47 Link
I used to leave mine in debug mode so I could change the setting when I attached a lens that required a big adjustment.
johnwhit
Posted 20/07/2011 - 08:33 Link
I calibrate half way through the zoom range (approx)
John
PPG link
In LBA hiatus.
ChrisR
Posted 20/07/2011 - 09:22 Link
Many thanks to Anva and Smeggy, for your input.
I have had a look on my K10, and I don’t have a debug option, but I think my firmware is the original, so maybe the debug was added in a later version.
Its not that much of a problem, its just that the focus does not have that, what I would call punch.
My wife uses a “Canon Power Shot A640”, only ever on set to auto everything, but the focus is spot on, also the annoying thing is,she is a far better photographer than me. She has that photographic eye, for composition.
Her dad was a very good artist, need I say more.
Take care and thanks again.
Chris R.
Chris R.
JohnX
Posted 20/07/2011 - 11:07 Link
No. The debug mode is accessed courtesy of a piece of non-Pentax software you download onto, and run from, an SD card.
I seem to remember Smeggy referring to it (amongst others) in another post.
i-Berg
Posted 20/07/2011 - 11:42 Link
I do what Smeg-P does - leave the K10 in debug mode permanently. And John is right - it's a firmware 'hack' for the K10 available for download over the net, which you put onto the camera's SD card initially. No guarantees with it - use at own risk. link
Edited by i-Berg: 20/07/2011 - 11:43
