Lens Droop
tyronet2000
Posted 11/09/2013 - 11:58 Link
I have a Giottos tripod "Y" center column with ball head (MH1300-652) but when I use the Sigma 150-500 lens I have trouble with keeping the lens in position, ie it "drops down". Any suggestions on preventing this.
Stan
Gamka
Posted 11/09/2013 - 12:39 Link
Do they make Viagra for lenses?
bforbes
Posted 11/09/2013 - 12:43 - Helpful Comment Link
One of these link allows you to balence the camera/lens set up so it stays in place when you leave go
geordie01
Posted 11/09/2013 - 12:46 - Helpful Comment Link
Is it ball creep or zoom creep Stan as the head is rated to 15kg
tyronet2000
Posted 11/09/2013 - 12:48 Link
Wow Barrie !! Just a bit more than I was looking for. If I used the lens a lot more I'd have no hesitation but the lens is probably the least used of those I have
Stan
Algernon
Posted 11/09/2013 - 12:58 - Helpful Comment Link
Hi Stan, I take it that your using the foot on the lens and not the tripod socket on the camera?
I would have thought a 4" B&S would hold it. It's normal for the lens to drop slightly when you let go you have to aim a bit higher to compensate and you have to tighten the screw really tight to hold it.
It's better if you can balance the lens and camera by using a longer
QR plate on the camera.
There's nothing like having a really substantial B&S head with friction hold, but they are expensive. I use two Novoflex ones which are really solid. Arca is the top one.
You might find this page of interest....
http://www.canadiannaturephotographer.com/tripod.html
smudge
Posted 11/09/2013 - 13:00 - Helpful Comment Link
You could try a longer QR plate so that you can adjust the balance point. Of course with the 150 - 500 the balance point changes dependant on the focal length chosen.
oops! overlapped with Algi's post
Regards, Philip
Edited by smudge: 11/09/2013 - 13:03
tyronet2000
Posted 11/09/2013 - 13:09 Link
I'll have to check for zoom creep but the lens as far as I recall was level. I had the main control knob and friction knob as tight as I could get them.
Sample of what I was taking, middle of lens on abbey but it "dropped" so middle of lens was at about half way between abbey and church. unstraightened pic
Yes, using the tripod foot. Will have to look at the longer plate.
Stan
bforbes
Posted 11/09/2013 - 16:59 - Helpful Comment Link
Could the tripod feet have sunk into the ground a little?
tyronet2000
Posted 11/09/2013 - 19:40 Link
I don't think so Barrie, but when it stops raining I'll go into the garden and test everything out and see what happens.
Stan
smudge
Posted 11/09/2013 - 20:31 Link
Try it with the tripod unextended to see if it still happens, just to check if there is some play in one of the leg joints or if the head is responsible.
Regards, Philip
Algernon
Posted 11/09/2013 - 21:19 Link
Have you checked the tripods got all FOUR Legs?
