Lens Cases for Small Primes - any suggestions
Posted 16/01/2009 - 11:10
The Limited lenses come with their own custom leatherette pouches where they sit as snug as proverbial bugs in rugs.
For older (small) primes I'd suggest looking at aftermarket bags for Leica lenses - the Pentax A28/2.8 is around the same size as a Leica R Elmarit 28mm and a quick scan of eBay turns up things like this: link.
At £9.90 including p&p the price isn't excruciating either!
Joining the Q
Posted 16/01/2009 - 11:54
Thanks Hefty1, but I'm not after a soft pouch for storing a lens, rather a tough case that I can wear on my belt with easy (one handed) access to the lens.
Posted 16/01/2009 - 19:06
Or mobile phone cases.. pop into a phone shop with the lens, check which case fits best, then buy the cheap Chinese version from ebay for 50p..
Liam
Liam
Liam
Posted 17/01/2009 - 14:08
The Lowepro Lens Case 1N is about the right width for the 49mm thread lenses - with a doubled up piece of bubble wrap as a horizontal divider, would give you a 2 lens carrier which could be put on a belt.
Posted 23/02/2009 - 17:30
David, check out these, the ZING lens pouches:
http://www.speedgraphic.co.uk/cat.asp?usrID=F7EF982B-D2A6-4FFC-AFB0-B837247DBD45...
cheers Steve.
cheers Steve.
Posted 24/02/2009 - 02:43
Get some old Takumar lens cases and put some foam in the bottom if they are little loose. But as Hefty says, I would prefer to use a pouch, doesn't take up as much room in your bag.
Camera:|K-7|
Posted 24/02/2009 - 09:13
Be careful about storing lenses in pouches - they can end up a very nice incubator for fungus.
Posted 24/02/2009 - 09:31
Your right John and I don't leave them in the pouches when not in use.
Camera:|K-7|
I have a "LOWEPRO Lens Case 1S" which does the job fine for larger diameter (58mm) lenses, but I've failed to find any similar cases that are small enough to take (say) a 28mm f2.8 A. All the cases I've seen are too big, designed for big fat Canikon lenses I guess. My old Pentax primes just rattle around in them.
I guess this may be a problem with modern Pentax Limited lenses too, what do people keep their 21mm & 70mm pancakes in?
(To be absolutely clear, I'm after a case to take a single lens, attached to my belt - I don't like camera bags, or pockets full of lenses.)
All suggestions gratefully received, thanks.
