lens calibration
http://focustestchart.com/focus21.pdf
Still learning!
Zooms: DA12-24 | DA16-45 | DA*50-135 | DA55-300
Primes: FA31 | DFA100WR | M50F1.7
Fun: LensBaby Composer + Kit
http://pentaxdslrs.blogspot.com/2008/06/part-1-autofocus-adjustment-for-pentax.h...
Vic.
K5, LightRoom 5
regards
Roy
Pentax K3 gripped,and some lenses
https://www.flickr.com/photos/pentaxroy/
my pbase gallery
I suppose this is what you are looking for =)
This is the one I use
Or you can use a tape measure
I'm always hesitant about using a tape measure. How can you be sure what the camera is focusing on?
Tim
I use Yvon Bourque's one(the link from xbow above).
Well the little red square in the view finder is pretty small. I assume that this point is the where the camera focusses.
I use the chart now but when used a tape measure it produced a calibration that worked.
Subject is amazed and smiles. You take picture, having preset the correct distance.
As for focusing tests, why not just choose a detailed subject, focus on it and see if it's sharp? You can forward and back focus slightly using QuickShift to check planes of focus just in front and just behind the subject.
I presume this needs doing at various zoom settings and various distances to average out any errors?
I've never found the little red square to be very accurate and the flat lens tests are pretty useless unless you stand something up vertical that you can actually focus on.
The expensive Lensalign is much better because it gives you a vertical target. The poormans solution is probably something along the lines of a Cornflake box with a 12" ruler on a 45deg ramp at the side.
It's also impossible to focus accurately by any means, every time so you need to take at least 4 shots and compare them.
http://67.18.178.219/videos/LensAlign.mov
I think I'll have to spend a few minutes drawing up something similar and making my own version.
Vic.
K5, LightRoom 5
Searching I found another method based on moire interference patterns. Didn't try myself. Anyone with experiences?
Hi. My name is Joel and I'm a travelholic.
Stolen kit: Pentax K7 #3428965 and Pentax FA 43mm #0028350
I should have said that I don't like any that I've tried but looking at the Lensalign system it does look a better proposition:
Vic.
Over £100 - WTF!!!
I didn't consider a vertical surface would be better for focus. I can see why.
I could knock something up like the lensalign in about 20 minutes out of MDF.
In fact I will soon
My Images
K1 II|K3|DA10-17|DA*16-50|FA31|DA*50-135|DA*200|DA*300|Sigma 150-500
I often use my computer keyboard leant at a 45 deg angle. I just focus on a specific letter key and check the image to see if the same key or the ones in front or behind are the ones in focus
cool might try this too
regards
Roy
my pbase gallery
royd63uk
Member
Newport, South Wales,U.k
regards
Roy
my pbase gallery
