Left bar flashing in bracketing mode (K-5 II)
I have had a play and I can't make it stop, even by pointing it into the light or by putting it on ISO 51,200, or winding the 3/5 exposures way above centre so perhaps that just the way it's supposed to be. I tried my K-r and that is the same. I'm beginning to think that it was like that all along but I didn't notice.
Mind you, I do wonder why some one would design it like that - something flashing usually means 'look at me', or 'there's something wrong'.
It indicates the order in which the bracketed exposures will be taken. More specifically it tells you the first exposure to be taken. So I have the order set (for 3 exposures) to be - 0 +, which means the lowest exposure is taken first then the middle, then the highest exposure. So the left most bar flashes.
If I set it to the default, 0 - + , the the centre bar flashes.
I think I must be a geek! I'll just crawl back under my stone - don't mind me!
I must admit I have wondered if it could ever make any difference at all what order your brackets are shot in ... Now I'm also wondering when we would ever need to be informed of what order they will be shot in !
The default on my camera, and I assume on all Pentax cameras, is the centre one first then lower and then higher. The order determines the naming hierarchy, so I suppose knowing how it is set directly from the display is useful(ish)!
13 years
Tyneside
Thanks in advance
Website
