K3 autofocus not working
Posted 25/06/2015 - 13:19
There are some things you can try. Factory reset is one, but first try taking out the battery, leaving it for a few minutes and then re-inserting it. Also, try cleaning body mount and lens contacts with a dry, soft cotton cloth.
Posted 26/06/2015 - 13:54
Thanks John
I have tried those suggestions with no success.
Paul
Paul
I wonder if I have an incorrect setting somewhere or have hit the wrong button!
The symptoms occur with sdm lenses and screw drive lenses but all these lenses work fine on a K5. The problem appears to be with the K3 body.
The camera tries to focus but the lenses hunt , as on a macro lens trying to focus.The diamond focus confirmation does not appear in the viewfinder if I focus manually.
I have tried the different focus modes AF, AFC and different focus AF points.
camera firmware 1.11
However it works ok in live view. I never use live view so that was a surprise when I just tried it.
I saw on the US forum a reference to cleaning the focus detector on the base of the mirror box but am a bit reluctant to do that.
I spoke to SRS who had not come across the problem and suggested a try a reset. Again I am not rushing to do that as all the lens AF adjustment settings will be lost.
Has anyone experienced this problem or can give advice for solving it.
many thanks
Paul
